Disaster Buying SATA Connectors
Discussion in 'Modding' started by error2061, 7 Jul 2008.
  1. error2061
    error2061 9800GX2 is dead long live 280GTX
    13 Jun 2008
    Hi does anyone know where i can buy:-
    SATA Power Connectors
    Black Molex
    Connectors like the ones that go into MB ATX
    PCIE power
    all in black
    The SATA seperate connectors are the most important
    I have a modular PSU but want to change the lengths of some of the connectors and the SATA connectors seam molded so i need new connectors
    thanks in advance
  2. wongy2803
    wongy2803 What's a Dremel?
    24 Jun 2008
    Maplin sell some of power connectors especially molex and motherboard not so sure about Sata and PCI-e though
  3. frizzeh
    frizzeh What's a Dremel?
    5 Jul 2008
  4. lost_modder
    lost_modder What's a Dremel?
    5 Dec 2006
  5. error2061
    13 Jun 2008
    Hi to lost_modder
    The sata cable mod was interesting but my connectors are molded, and my soldering skill are not that good
    Hi to frizzeh
    The AC ryan Kit only has 2 and i need at lest 4 but thanks for finding it much appreceated !
    EDIT the bigger AC Ryan Kit my be just what i need.
    Hi to wongy2803
    I actuly work at maplins and they dont do SATA, they do molex, but not black molex, but thanks for the thought.
  6. connec
    connec What's a Dremel?
    15 May 2008
    Buy two? :rolleyes:
  7. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
  8. error2061
    13 Jun 2008
    Another reason for doing this is that i want to put 3 HDD together in a rack but the current psu the wires go in and out, they they are not T-Type whitch is what i want and you have now showed me where to get them from. but i think i will go for the ac ryan kit
    Thanks
    __________________
    BFG 9800GX2 | 4GB PC6400 | Fatal1ty FP-IN9 SLi | Q6600 1TB SATA HDD | Xilence 1000W Quiet PSU
    __________________​
  9. TheAbyssDragon
    TheAbyssDragon Gafgarion
    8 Dec 2005
  10. error2061
    13 Jun 2008
    hi ok i seem to have found all the connectors i originaly wanted but now the 4pin fan connector needs to be black anyone lnow where i can get one from
  11. lost_modder
    5 Dec 2006
    the link on post #7 has black 4 pin molex connectors.
  12. error2061
    13 Jun 2008
    yes it has molex but i need 4 pin (PWM) fan connectors on core 2 duo and higher mbs
  13. lost_modder
    5 Dec 2006
    you sir, need some black vinyl dye in that case. I havn't seen anything but the white ones
  14. error2061
    13 Jun 2008
    yes that seems perfect where can i obtain this ?
    thanks again
  15. lost_modder
    5 Dec 2006
    this should help vinyl dye
    here almost every Autozone, Advance, Pep Boys etc has it. so try the link above or go to auto parts store
