Peripherals Buying Webcam
Discussion in 'Hardware' started by SpaceBaby, 2 Jan 2011.
  1. SpaceBaby
    SpaceBaby AKA: Stophon
    1 Aug 2008
    Well i am looking to buy a webcam to use on stuff like Skype and was wondering if i could get some help finding one.
    i have £20-£25 to spend, dont want to spend more than that. but not sure how good a quality an image you will get from it.
    so as usual i will come here, a place i know there will be someone who knows a lot more about the subject than i do and a guy at curys will.
  2. BennieboyUK
    BennieboyUK CPC Folder of the Month Sep 2011
    24 Nov 2010
    £25.00 gets you the Logitech C310 HD. Currently on offer at PC World, which shockingly make its the cheapest.
    If you go a little higher, the Microsoft lifecam cinema is an awesome lens, but costs more at 35.00 at ebuyer, and the software is not as good as Logitech.
    Nothing else to consider at that price. Imho
  3. Hazmatt
    Hazmatt What's a Dremel?
    4 Dec 2010
    A logitech C120 will set you back $25 AU and is 1.3 MP
    I'd also advise you to look at ebay
  4. Jehla
    Jehla Minimodder
    8 Jan 2010
    Are the microphones on these things good enough for use in skype/ vent etc or is a proper mic needed?
  5. trigger
    trigger Procrastinator
    22 Mar 2004
    The built in mic is usually fine for Skype, but it kinda depends on how it's being used, e.g. what else is in the room, where is the cam placed, etc. If you're using it in a fairly normal fashion (cam on monitor, about 2-3 feet tops from you) you should be fine.
  6. Bertiee
    Bertiee What's a Dremel?
    20 Aug 2009
    Just to hi-jack this - can anyone suggest something around the £15 mark? All I'll be using it for is Skype so it doesn't need to be fantastic, but I might as well get the best I can for the money.
