Modding BYO case : aluminium thickness
Discussion in 'Modding' started by abreev8, 21 Jan 2004.
  1. abreev8
    abreev8 New Member
    4 Jan 2004
    I'm looking into building my own case and I am considering using aluminium, acrylic, or both. No pieces would need to be larger than a mini-tower case as I would like it to weigh <10 pounds (~4.5kg if I am not mistaken). That said, I was wondering if anyone has experience using aliminum sheet. What thickness would be adequate for supporting a PC. 1/4" acrylic seems to good enough for just about anything. 1/8" for drive cages. But then again, that's just my guess.
  2. metarinka
    metarinka New Member
    9 Feb 2003
    I'm no master of fabrication, but I believe if you want to build an alimunum case, your best bet would be some sort of support structure, with 1/8th or below siding, as the the sheet metal by it self would be hard to fabricate into a case, and for acrylic I tend to use 2-3mm which translates out into about 1/8th inch I believe
  3. ynema
    ynema New Member
    27 Oct 2003
    As long as you have a structural frame say square 10mm aluminium tubing then you could use 1.5mm aluminium sheeting as long as the case isn't going to be likely to recieve any heavy structural forces (ie. someone using it as a seat as i do but my lian-li seems to be able to support me weight just on its structural beams which are just aluminium 90 angle section.) You might want to make the plate that holds the mobo thicker or just have two layered. in order to support the weight of the board. Or if you know anyone or can find check out the construction of lian-li cases or any other decent aluminim cases.
    also 1"=25.4mm if you need that.
  4. abreev8
    abreev8 New Member
    4 Jan 2004
    Thanks for the input. I have an Antec Lanboy and it seems to be made almost completely out of 1mm aluminium sheet. But, many think it's a flimsy case and I would agree somewhat. However, it is pretty light.
  5. Cabe
    Cabe New Member
    14 May 2002
    ahh the old BGA* routine
    *butt-to-ground adaptor
  6. instant rice
    instant rice New Member
    20 Jan 2004
    i recommend getting a strong support structure. maybe consider using steel for just your basic box shape just to have the added stability. home depot sells lengs of steel bent in 90 degree angles with slots cut in them to make them lighter. they also have [ shaped pieces, also with slots cut in them (in the wide part). they're very light. one 4 foot section (1.3m) weighs a little over a pound.
  7. abreev8
    abreev8 New Member
    4 Jan 2004
  8. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
  9. Providence
    Providence New Member
    23 Jan 2004
    As far as binding agents, hinges, angle iron...any ideas? I like where this is going, but I'm lost as to how I'm going to hold the whole thing together.
  10. ynema
    ynema New Member
    27 Oct 2003
    Well if you can weld then that's good cause you can weld up your structural frame and then use bolts to attach the panels on. When I get round to building the case for my Theatre box I'm going to be welding the square tube frame up then Using the same Hex Socket bolts I used for my other Case mod to hold the panels in then a few rubber grommets in a select number of sockets and you have some pretty cool case feet. But if you can't weld then try and base you stucture around some corner brackets I saw someone in these forums looking for the before I think the were something like Plactic Corners that tubes fitted around and you screwed them into place. or just go to you local hardware shop and have a chat with someone who knows what they are doing
  11. 1398342003
    1398342003 Ubermodder
    2 Sep 2002
    I'm building a case out of 1/16" Alu, the sheets seem to be strong enough to support my weight, although I don't want to test that and bend them. :D I would think that 1/16" would be more than sufficient
  12. Captain Slug
    25 Nov 2001
    For the simplest to implement/assemble I recommend using 1/4" sheets for the top and bottom panels. This would allow you to drill and tap holes into the edges of those sheets so that you could screw-mount the other case panels.
    Welding aluminum is particularly difficult and unless you're a seasoned machinist I don't recommend it with such a small gauge.
    And I still recommend 1/8" simply for the added strength.
  13. abreev8
    abreev8 New Member
    4 Jan 2004
    Is aluminium any lighter than acrylic, or whatever kind of clear plastic, of the same strength? From a few numbers I found at this onlinemaetals place I mentoined earlier (they sell plastics too) it doesn't seem to be. In that case I will probably use mostly acrylic. Due to the design for my case I hatched up, I wont need to remove most pieces and can glue it together for a more seamless effect.
    Does anyone know the advantages of using different plastics or metals (plexy, polycarbonate, lexan, aluminium, etc.) for a project like this? I want it to be light.
    Has anyone had experience glueing acrylic/plexy/polycarbonate/etc.?
  14. Captain Slug
    25 Nov 2001
    1. Aluminum is marginally heavier per dimension than Plastic, but is stiffer than plastic in comparable thicknesses.
    2. Polycarbonate (Lexan) is much more pleasant material to tool than any comparable material since it's resitant to temps upto 375F. Acrylic/Plexy however melts at very low temps and will leech toxic fumes when heated.
    Both materials are comparable in price if you order them from an industrial supply company.
    3. Most plastics can be melt-welded with chloroform, or adhered together with plastic specific epoxies. DO NOT use a generic epoxy or adhesive or you may permanently cloud or deform the applied areas. If you need help choosing the right adhesive consult a local plastics shop or http://www.usplastics.com
