C² [stealthed drives 24th]
Discussion in 'Project Logs' started by Incorpirate, 18 Jan 2004.
  1. Incorpirate
    Incorpirate What's a Dremel?
    2 Jan 2004
    that mod is fine for when i get my lcd screen but i want ot stealth the cd drives...
    and yes pixelness rooooooools ive done hundreds of stuff.
    my site is:
    http://www.pigpictures.co.uk sadly taken my pixel stuff off but the site is all pixel :D
  2. Incorpirate
    2 Jan 2004
    know it sounds dence but does any one know how do get the cd drives back further in the dragon cases without cutting those metal stopper things in the drive bays off.. .cheers :)
  3. theagent
    theagent What's a Dremel?
    4 Nov 2003
  4. Incorpirate
    2 Jan 2004
    dont yah just love b3ta terms
    anyway el wire testing:
    i prefer it this way though:
  5. maeterlinck
    maeterlinck What's a Dremel?
    14 Jul 2003
    there are multiple holes on the fixing mounts. use a set that are closer to the front. For instance: you should be using the set furthest away at the mo.
    Good luck!
  6. Fr0z3n
    Fr0z3n What's a Dremel?
    21 Oct 2003
    I like the way that El Wire looks. I think you should put it both ways though. All the way around and in the grill. That would look cool. :clap:
  7. Hallq16
    Hallq16 What's a Dremel?
    30 Aug 2003
    :jawdrop: I didnt have any idea that el wire looks sooo good!!
  8. Meatloaf
    Meatloaf What's a Dremel?
    3 Nov 2003
    Nice work with the Elwire. I really like where this is going.
  9. Incorpirate
    2 Jan 2004
    thanks for all the comments guys
    been learning alot from this for my summer project :D
    dont have neough el wire :(
  10. Incorpirate
    2 Jan 2004
    that jus makes it stick out even more
  11. maeterlinck
    14 Jul 2003
    can you post a photo of the rails and where the screws go though?
  12. Incorpirate
    2 Jan 2004
    rails
    the things that stop it goign back any more
  13. Fubar
    Fubar What's a Dremel?
    7 Oct 2003
    i hate those rails with a passion... grrr i pushed my cd drive to far i guess once and it wouldnt come back out... the thing went past the stop tab and caught on it for the life of me i couldnt un do it i ended up drilling out practically all the rivets on my case to get it out.... that was the best several hours ive ever wasted
  14. Incorpirate
    2 Jan 2004
    they are fine for quick release.. but im not a thief...
    the case is fine but i cant wait till i get my lian li
  15. Incorpirate
    2 Jan 2004
    still need help on stealthing the drives on this case bu until then heres a teaser at what ive got planned for the summer
  16. maeterlinck
    14 Jul 2003
    humm, how pants. The ones that come with the Chieftech versions are much better... the only option would be to drill new holes. not an incredibly difficult thing to do. Measure as far back as you can go, you will need to butcher the end to get the screw in. Make sure the front holes go though the metal clip.
    Should be possible.
  17. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    I find those sliding clips for the drives kinda annoying. They're fine and easy to use on the mid-towers, but on my Chieftec full-tower you have to take off the entire front panel of the case to access the tabs to pull the drive out. Very inconvenient IMO. :(
  18. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    hey, nice case!
    Are you gonna get rid of that case when you buy your lian li? cus ill be willing to make an offer :)
    also how does the door open when you have the EL wire over it?
    like in this pic
  19. Visualaid
    Visualaid What's a Dremel?
    15 Apr 2003
    hey incorpriate the screenswe getting not that small :D.
  20. Fraggster
    Fraggster What's a Dremel?
    30 Dec 2003
    its an AT mobo, probably socket 7 no faster than 500mhz.............
