C² [stealthed drives 24th]
Discussion in 'Project Logs' started by Incorpirate, 18 Jan 2004.
  1. Incorpirate
    Incorpirate What's a Dremel?
    2 Jan 2004
    not sure wther to get rid of the case or not yet...
    the el wire in that pic would be drilled jus under the door and then come back out...
  2. Incorpirate
    2 Jan 2004
    i looked at the dimentions and the actual screen looked about that big
    ( i did a paper mock up :p )
  3. Incorpirate
    2 Jan 2004
    tis all salvaged stuff.. the mobo will be changed soon as this pc is jus a piss around £100 spill.
    it gunan be a linux for other things
    the lian will be my personal pc which i can use for college etc this is just an experiment
  4. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    like the idea for the future plans.. :)
  5. Incorpirate
    2 Jan 2004
    *update*
    stealthed:
  6. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    very nice..and sleek :thumb:
    now...loose the floppy :grr:
  7. dirtbiker
    dirtbiker What's a Dremel?
    24 Dec 2003
    You know you want to viynl dye the drive plates (right word has gone from my head)
    Looks much better though, and the el wire is a nice touch.
  8. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    how was the el wire stuck on the outside of the case? :)
    nice stealthing btw :)
  9. maeterlinck
    maeterlinck What's a Dremel?
    14 Jul 2003
    way hey! nice one. looking good. guess the floppy is next?
  10. TX297
    TX297 Hey guys have you heard of seenly?
    28 Oct 2003
    Incorpirate, you could put a keyswitch where the power button was to enable / disable the power switch. I have one around here that you can take the key out at any stage (on/off) so you could enable and disable the switch for security or if you have a 1y/o sister running around *cough*
    -TX297
  11. TMM
    TMM Modder
    12 Jan 2004
    DAMN this is looking so much like my antec its freaky!
    i like the first idea with the EL, i might do that :worried: not to steal your ideas lol. just need to drill some holes in the door and presto :p
    anyways. about your LianLI idea, the dual fan idea at the bottom will be difficult since the drilled (square) vents are larger then your holes that you want, so you'd probably have to bondo it and paint it or make a new front panel, or you could cut a piece or alum and put it over the front, covering the holes. good luck anyways
  12. Incorpirate
    2 Jan 2004
    lol yeh i noticed that when i shopped it :p
    im prob not doing a lian li as i want to water cool the case and ive found £30 case which has lots of potential so im gunna rip the front and do my own front on. :)
  13. 3N1GM4
    3N1GM4 What's a Dremel?
    23 Jun 2003
    DIE DRIVE RAILS DIE... cool idea, bad implimentation if you ask me...
    im doing a completly bondo'd front on cheiftec and in filling in those "finger slots" (the ones where the rails stick out) so i gotta figure out how to get the drives to stay in lol :D
    hope you get it done, it looks good so far
  14. fg0d
    fg0d Banned
    18 Jan 2004
    you mind if i steal the idea on my next pc?
  15. Incorpirate
    2 Jan 2004
    knock yourself out
