Scratch Build – In Progress C&C tiberium wars Advanced flame tank
Discussion in 'Project Logs' started by diecyde, 11 May 2010.
  1. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Just out of interest - why sand cast that particular piece? It looks like it would have been easier to just mill it out of billet aluminium as it's not a hugely complex shape. Great work, anyway!
  2. diecyde
    diecyde What's a Dremel?
    10 May 2010
    I find round shapes the hardest to create, and especially recreate the same thing once again (just like the other)
    rather hard.
    If I had a CNC router I would probably have done it that way.
    But I needed 2 identical caps and for me sand casting was the simplest way to achieve a good result then.
  3. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    There is nothing, absolutely nothing compared to this!
    It makes me proud that this is coming from a fellow countryman!
    I would walk from Eindhoven to Amsterdam to see this baby in action ...
    Keep Up The Brilliant Work
  4. diecyde
    10 May 2010
    I would do the same to see your mod when its done ;)
  5. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    this is SO sick! =D and you have a good taste for tools =D
    <---- sells industrial tools for a living (ae. metabo, makita) =)
  6. Samaya
    Samaya Lion Country
    2 Jan 2008
    I am very impressed with your mod. It is fantastic.
  7. diecyde
    10 May 2010
    Thank you so very much,
    I am currently translating another update.
    Hope to post it soon!
  8. diecyde
    10 May 2010
    Some components arrived, now preparing to solder the PCB's
  9. Cheapskate
    13 May 2007
    Surface-mount electronics? Now you're just showing off.:D
  10. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    That looks like you've got alot of solder ahead :)
  11. diecyde
    10 May 2010
    Yes, especially the MLF packages take a long time because I don't have solder paste and a reflow oven.
  12. Samaya
    Samaya Lion Country
    2 Jan 2008
    With MLF packages I usually place them first. I "tin" the pads and use a heatgun to flow the solder to the pins. But this only works when you have nothing else placed otherwise the other components tend to fly off...
  13. diecyde
    10 May 2010
    I sometimes use kapton tape to protect other small devices from my heat gun.
  14. GCOFIELDD
    GCOFIELDD Minimodder
    10 Oct 2010
    In the past, for dual sided boards, I have used two different solder pastes that melt at different temperatures, that way the components don't fall off one side while your melting the solder past on the other. I used a toaster oven...worked very well. Solder past is easy to get also.
    I like your ambition, but do you have a friend who could help you with the welding?
  15. diecyde
    10 May 2010
    It is a part of my job description, thus I should be able to do it :p
  16. GCOFIELDD
    10 Oct 2010
    That must be a crazy job description becuase you are doing a lot of stuff:thumb:
  17. diecyde
    10 May 2010
    I am an Electrical engineer and (embedded) software programmer for my work.
    I also am an linux developer.
  18. diecyde
    10 May 2010
    I have soldered and tested 2 PCB's up till now:
    The bluetooth pcb and the main controller board pcb.
    First I warm the pcb up to a temperature of around 130 degrees celcius, after that I bring the hot air soldering iron close to the chip for about a minute (till the chip solders itself to the pcb.
    Naturally I use some no-clean flux, this makes the solder flow better.
    an indication of MLF technology (this is an 20 eurocent coin)
    First I attach solder to the chip and after that I relow it to the pcb, I let gravity to the hard work for me.
    Also here I am warming the PCB before reflowing.
    This is the main controller board, tested and ready.
    There are also components on the bottom side.
    And a closeup of the bluetooth PCB
  19. alain-s
    alain-s Minimodder
    12 Jan 2011
    nicely done really
  20. diecyde
    10 May 2010
    The PS3 power supply is done and all works in the first try.
    Up till now I only found one small design error (this was easely corrected bij removing a small wire).
    Below You can see the bottom, the diodes and mosfets stick out significant.
    And here the top part, This PCB is completely self sufficient.
    But I still added a small processor with I2c bus, this controller monitors the power usage of the PS3 and can shutdown and start it up when needed.
    Also the main controller board can do these actions through this controller.
    I have tested the stability of the design from 8-24V with 0-2.5 Amps, no problems have been found.
    The signal is and stays perfectly stable with hardly any ripple.
    (I can't go higher then 2.5A with my LAB power supply)
    Picture of the ripple at 10V, 0Ampere measurement range: 20mV per decade, frequency of the pcb is now 389KHZ and the average ripple is 0.054V Peak to Peak.
    Picture of the ripple at 10V, 2Ampere measurement range: 50mV per decade, frequency of the pcb is now 397KHZ and the average ripple is 0.148V Peak to Peak.
