Scratch Build – In Progress C&C tiberium wars Advanced flame tank
Discussion in 'Project Logs' started by diecyde, 11 May 2010.
  1. Jake123456
    Jake123456 Surprise!
    25 Jan 2011
    :eek:.....wow.....
  2. Samaya
    Samaya Lion Country
    2 Jan 2008
    Me too!!! :D Just not Linux :nono:
    Your PSU is looking good. Hod does it compare to the PS3 PSU?
  3. diecyde
    diecyde What's a Dremel?
    10 May 2010
    :rock:
    Sadly I didn't try it out yet.
    Currently I am soldering the motor PCB's
  4. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Thats some neat soldering :thumb:
  5. diecyde
    10 May 2010
    Thanks,
    Now I am soldering and testing my motor PCB's
    Hope to show you the pictures soon!
  6. diecyde
    10 May 2010
    Today I also started on the motor PCB's.
    These PCB's can drive DC motors and have various feedback methods (motor power usage, step pulses, analog feedback (for servo functionality))
    Using the flux pen to add some flux to the PCB, this allows for easy soldering of the small components.
    After that I apply some solder to the pins of the chip (I don't have solder paste)
    With the programmer I check for any mistakes.
    The connector I am using to program this PCB is a piece of an PCI connector salvaged from an old mother board.
    This is a close-up, not all components are attached yet.
    I only continue when all is checked for errors.
    Now the PCB is finisched, no problems have been found, I placed a 20 eurocent coin next to the PCB so you can compare its size.
    This is how It will get attached to the motor, the PCB is then controlled using I2c.
    And the front of the track, you can see the pcb is well protected on its current position.
  7. BrokenJaw
    BrokenJaw What's a Dremel?
    16 Jun 2011
    So many insane things in this.
    Did you ever finish it?
  8. morbid_looney
    morbid_looney What's a Dremel?
    27 Apr 2010
    I was thinking the same thing
    I hope you find some more time for it :)
    ITS AWSOME
  9. diecyde
    10 May 2010
    Time is usually the issue.
    I am still working on it, the work goes on slowly as I am machining various small parts for the tracks now.
    It is hard to photograph all the things I have done, that is why the updates are taking a while currently :(
    Also I have been doing a lot of software for the tank.
  10. rayson
    rayson Damn sure it was legal
    23 Jul 2010
    this is gona be awesome
    so
    when are going to make the life size version
  11. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Dear God, that circuitry looks horrible to solder. Amazing work!
  12. Gentleman_Dingo
    Gentleman_Dingo What's a Dremel?
    30 Aug 2007
    Ok, another person that's doing aluminum casting? Subscribed. I have tool envy. Your shop is amazing. I would kill for half of your tools and that CNC.
    Have you tried lost foam casting? It saves you a bit of time and gas over doing a 2 part impression mold.
  13. Waynio
    Waynio Relaxing
    20 Aug 2009
    Hope to see this completed some day, just thought about this & had to look it up again, as far as I'm concerned I think you are Yoda or even his masters Master :eeek::D:rock:.
  14. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    live action flamethrower tank??? with ps3 inside??? with cast parts??? definitely follow this!!!
    excellent metalwork, awesome soldering and brilliant flamethrower!!!
    *subbed*
  15. TotalGaos
    TotalGaos Stainless steel.. hmm..
    16 Dec 2007
    Love this build! What has happened to that 20c coin?
