Development C# help please
Discussion in 'Software' started by NikoBellic, 9 Jun 2010.
  1. NikoBellic
    NikoBellic Tech Addict
    9 May 2009
    I've managed to develop my first app, but, I want to improve the compatability, so I was wondering if someone could possibly help me with my problem
    The problem I currently have is that if the target that I tried to launch isn't possible to launch (eg: the file or app isn't on the system) then I get a message saying 'unhandled exception has occurred in your application'.
    So I was hoping that someone could tell me if its possible to have some kind of "2nd Target" to launch if the "1st Target" fails
    heres an example the line of code I use to launch apps
  2. Bakes
    Bakes What's a Dremel?
    4 Jun 2010
    Code:
    private void Button1_Click(object sender, EventArgs e)
        try
             // Attempt to start the process
             System.Diagnostics.Process.Start("explorer");
        catch
             // What happens if the process doesn't start
             System.Diagnostics.Process.Start("explorer2");
        catch
             // We can use catch more than once. This is only executed
             // if the statement above also fails ie if it succeeds this is ignored.
             System.Diagnostics.Process.Start("explorer3");
    I'm not a C# expert, but based on other languages the above snippet should work.
  3. Geoff x
    Geoff x What's a Dremel?
    6 Sep 2009
    CodeProject has a large number of very good articles on various languages, inculding C#.
  4. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    [thread hijack]
    How easy is it to learn C#? I've been wanting to learn some programming for a while and I'm trying to find a language to start from. I was originally going to try VB but have been told by a few people to go for one of the C based languages.
    I'm talking learning everything from principles to hard coding. Did a little pascal in college but that's about it, and I've forgotton 99% of it.
    [/thread hijack]
  5. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    no shame in learning vb.net, depends what you want to actually write to how viable it is.
  6. NikoBellic
    9 May 2009
    @Bakes & Geoff: Thanx for your help. I'll try that stuff later! :)
    *sigh* The thread Jacker... Keep it up and you'll have your own channel 4 series lol :p
    Anyway... Yeah, I started with C++, and that was a little difficult, but with C# things are a little easier to understand, I started developing my app in about march, and I've nearly finished it now, its only a basic app but its good to do something basic to get an understanding of the C# language to start with!.
    PS,
    I use Visual Studio 2010
    Seems easy enough to get used to as a noob to sw developing
    Anyway, Good luck! :)
  7. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    Try...Catch would be the easiest way to handle it. That's what it's there for.
    For Brooxy:
    C based languages have their advantages. The biggest one being that the syntax is often similar.
    VB.Net vs C# is really mostly preference. They both run on top of the .NET framework, and as such can pretty much do the same things. I prefer C# simply because I use C-Based langauges a LOT, but others prefer VB.
  8. Daedelus
    Daedelus What's a Dremel?
    7 May 2009
    Yes, as has been already stated you catch exceptions with a try....catch construct.
    Just to add one more thing to this, there is also the finally keyword. You can also catch the actual exception
    Code:
        try
             // Open a connection to a database
             string connectionString = "Data Source=myserver.com;Database=d";
             SqlConnection cn = new SqlConnection(connectionString);
             cn.Open();
             // Do something here with the connection......
        catch(Exception e)
             // Exception handling
             Console.Writeline(e.Message);
        finally
             // The code in the finally block always executes regardless of what happened
             // in the try and catch block
             cn.Close();
    In this case, you will always want to close your connection. The code in the finally block always executes whether you get an exception or not.
    BentAnat likes this.
  9. BentAnat
    26 Jun 2008
    Finally... heh... forgot about that. Absolutely right
  10. NikoBellic
    9 May 2009
    *EDIT*
    Dunna matter...
  11. Bakes
    4 Jun 2010
    If you want to find a good language to introduce you to the basics of programming, try python. The manual is excellent with loads of examples, it's a well supported language, it's pretty easy to pick up and because of the indentation system it's easy to use. Furthermore, it can be both a procedural and object oriented language, so it's good in that respect.
    In terms of a language in the C family, I'd learn C++ or C itself.
    My reasoning is threefold. Firstly, they're well known languages and are both standards, as set by ANSI and ISO.
    Secondly, they're not covered by patents in the same way that C# is. Microsoft holds all the keys to C#, which means that it's generally quite hard to get your C# code to run on systems other than Windows. There are systems, such as mono, but some people fear that Microsoft could sue people who use it commercially. Thus, Mono is largely avoided.
    Finally, C++ is a language that is used across operating systems. If you want to write for Mac or iPhone, you can write in C++, whilst it's almost impossible with C#. You can write for Android and I believe WebOS with C++, again C# is difficult.
    They might be more difficult to pick up, but they're much more widely used languages.
  12. glaeken
    glaeken Freeeeeeeze! I'm a cawp!
    1 Jan 2005
    C# is fairly multiplatform nowadays.
    Windows + XBOX + Windows Phone = win. Mono supports .Net 2.0 so if you stick to .net 2.0 and aren't creating graphics based applications, it will most likely run on linux.
    Plus C# is a much up to date language than C/C++. Supporting events, delegates, anonymous methods/types, properties, extensions, lambda expressions, etc. Some of these features are added by the new c++ standard and libraries such as BOOST. But C# has the advantage of the language being designed with these features and not being tacked on to a 20 year old language.
    Also, it's much faster to get stuff done in C#. The standard library that comes with .Net is fantastic. I find that when I develop with C# and .Net I just get stuff done much faster than I do in C++. There's so much built into .Net that I don't usually have to go search for a library that's implemented the functionality that I need.
  13. Bakes
    4 Jun 2010
    I'm not going to bother talking about features here, I'm just making my argument on the basis of portability and the fact that C++ is a standard.
    Yes, but there are several large arguments against Mono, and including it in Linux by default, so if you were to develop a Linux application, there would be large dependencies.
    I'm not sure you can use 'up to date' as an argument. Yes, there are different features in different language, and what you use them for usually dictates whether you need something. If you want to use 'up to date' as an argument, I'd probably point you towards python - it's got masses of really useful libraries in, everything from xml parsing to an http server.
    Faster, I guess that's personal preference. I know people who prefer C and I know people who prefer C++ to C#.
  14. NikoBellic
    9 May 2009
    I've come across another problem... when I try to make a 2nd "catch" the utility forces it to launch... heres the code that I've used:
    Code:
    private void button1_Click(object sender, EventArgs e)
                try
                    System.Diagnostics.Process.Start("Explorer");
                catch
                    System.Diagnostics.Process.Start("Control");
                    System.Diagnostics.Process.Start("DXDIAG");
    So if the code is identical to that above you'll find that it launches both explorer & DirectX Diagnostics... any help?
  15. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Shouldn't there be another catch before the last set of braces (the DXDIAG section)? So it will always run because it's outside the try...catch section.
    Or if that doesn't work, could you nest the try...catches? Like this:
    Code:
                try
                catch
                    try
                    catch
  16. BentAnat
    26 Jun 2008
    You're gonna have to nest them AFAIK:
    Code:
    try {
          something
    catch {
          try {
                something else
         catch {
                somehting else entirely
  17. NikoBellic
    9 May 2009
    Thanx I'll "try" that then lol :p
  18. BentAnat
    26 Jun 2008
    It's a bit of a PITA (handling them one by one), but it is possible to handle specific types of exceptions
    by going
    Code:
    catch (ex as System.[i]specific exception type[/i])
    that would allow (for example) to handle File not found exceptiosn SPECIFICALLY, and then (for example) go
    Code:
    MessageBox.Show("File not found. Put file here or GTFO");
    hope that helps
  19. NikoBellic
    9 May 2009
    lol thanx xD
  20. Daedelus
    7 May 2009
    FYI here is a list of the standard Exception types.
    http://www.developerfusion.com/article/1889/exception-handling-in-c/3/
    and a little code snippet example:
    Code:
    int a, b = 0 ;
    Console.WriteLine( "My program starts" ) ;
    try
     a = 10 / b;
    catch ( InvalidOperationException e )
     Console.WriteLine ( e ) ;
    catch ( DivideByZeroException e)
    finally
     Console.WriteLine ( "finally" ) ;
    Console.WriteLine ( "Remaining program" ) ;
    Of course you can always create your own if none of these are suitable.
