A/V C-Media AC97 sound controller CODE 10 ERROR
Discussion in 'Hardware' started by Roady404, 15 Jul 2005.
  1. Roady404
    Roady404 New Member
    15 Jul 2005
    After I reinstalled windows XP proffesional my sounds doesn't work.
    In device manager it says This device cannot start (code 10).
    They told me that it was a IRQ problem, change the IRQ and it works again.
    I tried different ways to solve that problem with the IRQ, in the bios I changed the IRQ to a free IRQ number, that didn't work.
    I had never have this problem before, Only this time I have A ati 9200 PCI card installed. So i tried to re-install win XP again only this time without the ATI card installed. This doesn't work eighter.
    All the latest drivers are installed and no other weird devices are connected to the PC.
    Does anybody know how to solve this problem?
  2. hitman012
    hitman012 Active Member
    6 May 2005
    Double click your sound device in Device Manager, go to the Resources tab, and see if there are any conflicts listed at the bottom.
    I also recall that a while back someone had the same problem with a C-Media device and rolling back to an older driver version - before the 29 May 2005 update, I think it was - solved it.
  3. Roady404
    Roady404 New Member
    15 Jul 2005
    I have looked at the resources and it doesn't show any conflicts.
    So that must be the reason that the IRQ didn't work.
    So I go try A older version of the driver and hope that's the solution.
    TNX so far
  4. Roady404
    Roady404 New Member
    15 Jul 2005
    My problem is solved tnx to the old driver.
    So i will close this tread.
    TNX again
  5. sap1957
    sap1957 New Member
    1 Aug 2005
  6. sap1957
    sap1957 New Member
    1 Aug 2005
    need driver c-media audio ac97
  7. sap1957
    sap1957 New Member
    1 Aug 2005
    need driver c-media audio ac97 for windows xp
