Development C# .Net Datable Help
Discussion in 'Software' started by PBear23, 22 Mar 2011.
  1. PBear23
    PBear23 What's a Dremel?
    4 Feb 2009
    Hey guys/girls,
    I have started a windows application to display data from sql server database.
    I have two tables, the first is a table containing vehicle manufacturers and the second is a list of models of vehicles with assigned atributes (model, engine size, power etc. the two are related.
    I want to be able to click on a cell in the 'make' table and it display all of the models(and assigned attributes) in the model table. Can anyone help?
    Kind regards
  2. Daedelus
    Daedelus What's a Dremel?
    7 May 2009
    You mean like a collapsible view so that when you click on a make it expands to show you all the models they make?
    If so, there is nothing in ASP.NET to let you do that. You'll need to use javascript to show/hide the rows in your table.
    In a nutshell:
    In the RowCreated event of your table you need to hide the rows containing details of the models e.g. e.Row.Attributes.Add("style", "display:none;");
    Add an onclick event to the rows containing details of the makes e.g. e.Row.Attributes.Add("onclick", "onGridViewRowClick(this);");
    In your javascript function (onGridViewRowClick()) show the models for each make when you click on it. You could use jQuery for that so you can use the toggle() function.
  3. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    even without ASP (i.e. Windows C#), you'd have to make a callback there to the next bit of data (be it from the db or already in memory), using the click events on the table cells.
    Or, a third party control, if ther eis one.
