Windows C# Split String Not Working
Discussion in 'Software' started by Captain Xarzu, 18 Aug 2012.
  1. Captain Xarzu
    Captain Xarzu What's a Dremel?
    22 Aug 2007
    Please Help. I wrote a C# program that reads code one line at a time. Each line has data seperated by tabs.
    Here is what my C# code is supposed to do. The line is supposed to be split into a string array by using the "Split" string methodIt is supposed to be spit read in text one line at a time and I use the "Split" method to group the line according to the tab character.
    But, as this screen shot shows, it does not work. Any idea why?
  2. tehBoris
    tehBoris What's a Dremel?
    30 Jan 2011
    Are you sure they are proper tabs and not some thing else? What happens if you split on space?
  3. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Could try pulling the ASCII value of each char out of the string and checking that the delimiter is a tab.
    As a "workaround" you could split on whatever the ASCII value of the delimiter is instead of splitting on the tab char.
  4. CDomville
    CDomville ^ I am THIS Possum
    4 Jan 2011
    Is your backslash escaping correctly? (i.e. does \\t work instead?)
  5. theshadow2001
    3 May 2012
    I'm going to guess you need some kind of loop to deal with split method in order to enter each output to an array element.
  6. Captain Xarzu
    22 Aug 2007
    It turns out a text editor replaced the tabs with spaces without my approval or knowledge.
  7. vantonbill
    vantonbill What's a Dremel?
    25 Oct 2012
    try like this
    string arr[] = line.split('\\t');
    http://csharp.net-informations.com/string/csharp-string-split.htm
    vanton.
  8. Daedelus
    Daedelus What's a Dremel?
    7 May 2009
    what you have there should work. Are you 100% sure the string tab delimited?
  9. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    text editors do that...
    Notepad++ helps find those relatively quickly, though.
