Planning C13 Left Angled Plug to C14 Mountable Socket Power Cable
Discussion in 'Modding' started by JULO, 14 Mar 2016.
  1. JULO
    JULO What's a Dremel?
    2 Jul 2010
    Where can I get a cable like this one? Approx. 40cm.
    Been searching through the Internet for hours and hours now with no success. I would be really glad if someone helped me out. I need one or two of those for my next custom build.
  2. Attila
    Attila still thinking....
    22 Feb 2008
    I won't list all the links but search for 'IEC C13 angled plug'.
    There are many options available at many sellers.
    The mountable socket can be purchased separately and the cable fitted.
  3. JULO
    2 Jul 2010
    Thanks for the tip.
    I wanted to avoid going this way but most likely I'll do so, because I still haven't found what I've been looking for.
  4. Arboreal
    21 Jan 2011
    It is an expensive option, but you could order one from Silverstone in Germany, as a replacement for the one supplied in an SG07 or SG08 case.
