Cable connector crimp list
Discussion in 'Modding' started by zogthegreat, 5 Feb 2020.
  1. zogthegreat
    zogthegreat What's a Dremel?
    10 Sep 2011
    Hi everyone!
    So, I'm planning a custom build and and I will need custom wiring for it. I've been asking around and here is a list of different wire connectors that I have been able to gather so far. Please feel free to add to the list in order to assist others.
    BTW, a big thanks to Big Elf for helping me with a lot of the connectors.
    NOTE - I'm not including links for digikey or mouser because I find their shipping to be way over priced.
  2. zogthegreat
    10 Sep 2011
    Molex SATA connector numbers:
    Molex 67926-0001 SATA Connector, Punch-down type SATA power connector with latch
    Amazon link:
    eBay link:
    Molex 67926-0040 Cap, Feed-through cap for SATA power connector
    Amazon link:
    eBay link:
    Molex 67926-0041 End Cap, End cap for SATA power connector
    Amazon link:
    eBay link:
    Molex 67582-0000 SATA Connector , Crimp type SATA power connector
    Amazon link:
    eBay link:
    Crimps
    Housings
    *** NOTE - I have personally had better results with these crimp style connectors than the push down style.
    Female SATA data connector:
    If your looking at making custom SATA data cables, here are some links for the female tips that I have found:
    MODDIY PC:
    FrozenCPU:
    Performance-PCs:
    *** BiG Elf also gave me these part numbers, but I have only been able to find them on digikey and mouser
    Molex 67581-0000 SATA Pin (Molex 67581-0001 for gold plated)
  3. zogthegreat
    10 Sep 2011
    Molex ATX/EPS connector numbers:
    20-pin ATX male power connector housing
    Molex Mini-Fit Jr 39-01-2205
    Amazon link:
    eBay link:
    24-pin ATX power connector housing
    Molex Mini-Fit JR 5557
    Amazon link: I can't seem to find the 24 pin connector on Amazon. If someone finds one, please let me know and I'll link it.
    eBay link:
    ATX 24Pin to 24Pin 90 Degree Power Connector Adapter
    Amazon link:
    eBay link:
    EPS12v 4 pin connector housing:
    Molex 39-01-2045
    Amazon Link:
    eBay link:
    EPS12v 6 pin connector housing:
    Molex 39-01-2060
    Amazon Link:
    eBay link:
    EPS12v 8 pin connector housing:
    Molex 39-01-2080
    Amazon Link:
    eBay link:
    Molex 39-00-0038 ATX Female Pin
    Amazon link:
    eBay link:
    Molex 39-00-0040 ATX Male Pin
    Amazon link:
    eBay link:
  4. zogthegreat
    10 Sep 2011
  5. zogthegreat
    10 Sep 2011
    Molex tools:
    Molex 11-03-0044 ATX Pin Remover
    Amazon link:
    eBay link:
    Molex 63811-1000 Hand Crimp Tool
    Amazon link:
    eBay link:
    *** The genuine Molex crimp tool runs about $50.00 USD. I'm using a Iwiss SN-28B ratcheting crimp tool that I paid $21 USD and I'm getting great results.
    https://iwiss.com/product/sn-28b-dupont-terminal-ratchet-crimper/
    Amazon link:
    eBay link:
    "There's a Molex punch down tool available for the Punch down Tool (0638133503) for SATA connectors but a CR-V 4 screwdriver bit is a lot cheaper and just as effective."
    (source Big Elf)
  6. Big Elf
    23 Apr 2009
    You should be able to extract a few more from this thread
    zogthegreat likes this.
  7. zogthegreat
    10 Sep 2011
    Thanks again, Big Elf!
  8. zogthegreat
    10 Sep 2011
    Japanese Solderless Terminals
    OK, this one isn't that common on motherboards, but the board that I'm planning my build with uses them for fan headers. Apparently, they are commonly used for battery connectors for model airplane, drones, etc.
    Pre-assembled wires
    Amazon link:
    eBay link:
    4 pin housing connector:
    Amazon link:
    eBay link:
    Crimp pins:
    Amazon link:
    eBay link:
    kim likes this.
  9. MADPC
    MADPC Minimodder
    10 May 2020
    thank you for the precious infos.
