Build Advice Cable management advice required.
Discussion in 'Hardware' started by Siwini, 6 Jan 2011.
  1. Siwini
    Siwini What is 4+no.5?
    14 Sep 2010
    Is this safe? I am working on a build for a friend and I am in a same boat unfortunately. What worries me is once I close that back panel and cable might melt or start on fire. The cable is too short to bypass CPU in anyway or make any curves. I am also planing on using Gelid Tranquillo to cool his 3.8~4.0Ghz down, but like I said it worries me that 8pin cpu power connector might come in contact with cpu back metal plate than what? What’s your thoughts on this?
  2. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Yep, those INSULATED cables are definitely going to cause a fire if they come into contact with metal (oh, say for example, any part of the case)
  3. Zurechial
    Zurechial Elitist
    21 Mar 2007
    That looks fine to me, I think what you've done is fairly standard practice. As far as I'm aware none of those cables ever get particularly warm during use unless something were to go very wrong.
    DroganuvHIN is just being a smartass, but as he points out those cables are all insulated anyway. :p
    Oh no he didn't!
    DragunovHUN likes this.
  4. Lord-Vale3
    Lord-Vale3 His Tremendousness
    1 Dec 2009
    You should be perfectly fine.
    Dont mind DragonuvHON
  5. GoodBytes
    20 Jan 2007
    That is perfectly fine, the wires only travel at most 12V. Not enough to warm up the wire, not even slightly.
    The only problem is that it's going to be a pain if you change something in your case. But ignoring that, it's perfect. Just don't tight up the cable to hard, you don't want to squish the wires, just hold them
  6. Siwini
    14 Sep 2010
    Thanks again. Stupid question, but does cpu back plate gets hot? Hot enough to start smoking wires? I never felt it or tested myself so yah...
  7. GoodBytes
    20 Jan 2007
    Hot no, Warm, yes. Can melt wires, no.
    But you want to let it cool it, so don't obstruct it with wires. Personally, I would make the wire go around it. But it should not cause any problem with the current setup.
  8. Siwini
    14 Sep 2010
    I would if I could, but wire is to short. Anyway bytes just want to say your replays are most appreciated. Thank you!:)
  9. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Such things exist as 8-Pin extensions. Find them.
