ive seen some pics of insides of cases by falcon northwest and voodoopc and others, and i was wondering if anyone knows how they hide all their cables? i have no idea how it is physically possible? like all i can see are wrapped ide cables that stretch between the drives.
Do you mean completely hide them? If so, you could make a channel for your cables, or you could drill holes in your case so they go behind the mobo tray/panel. I'm sure there are plenty of other creative ways to pull it off.
Using cable folding to tuck the flat ribbon cables behind my mobo tray, and then split loom and cable ties for my PSU cables cleaned mine up quite a bit. Just takes patience and creative routing to turn out a clean unobstructed case. Also doesn't hurt to vinyl dye the ribbon cables to make then less noticable...
