Modding cable sleeving
Discussion in 'Modding' started by sgr55, 10 Jul 2005.
  1. sgr55
    sgr55 What's a Dremel?
    24 Aug 2004
  2. scotty6435
    scotty6435 What's a Dremel?
    4 Sep 2004
    You take off the molex, pop a piece of heatshrink over the wiring and re-apply. The quickest and cheapest way is to use a normal cigarette lighter or, if you've got one, a butane torch. It shrinks easily so keep the flame movng or you'll scorch the rubber.
  3. m0ng0lh0rde
    m0ng0lh0rde What's a Dremel?
    5 Jun 2004
    Also a way to shrink the tubing would be a heat gun. Or, if your wife is into scrpbooking, mooch hers....
  4. mandy_modded
    mandy_modded Minimodder
    12 Mar 2005
    a hairdryer will work, but takes longer to shrink, but hey no risk of flame marks
  5. scotty6435
    4 Sep 2004
    I just heatshrunk a bundle of wires on my shuttle's PSU (NOT an easy job) with a pocket butane torch and it did the trick really easily. It's so hot, the flame is no-where near the rubber and all the rubber gets is a stream of hot air. Shrunk a foot in just about 30 seconds with no scorch marks! The end inside the PSU was done with a soldering iron though and that was a very messy finish :(
  6. The_Pope
    The_Pope Geoff Richards Super Moderator
    3 Jul 2003
  7. Phaeton
    Phaeton What's a Dremel?
    8 Mar 2005
    Also, when popping off the molex endings, be careful with the flimsy tabs that hold the pins in the plug, they can break off rather easily.
  8. HellRazor
    HellRazor What's a Dremel?
    26 Jun 2005
    I find its best to just invest in a good pin remover....I broke none with that, while I broke quite a few using a needel to push them in, and pull them out.
  9. NOMIS
    NOMIS What's a Dremel?
    7 Jun 2004
    Yep the quickest and most hassle free way is to just buy a remover. Makes life so much easier :)
  10. scotty6435
    4 Sep 2004
    Got the black syrine looking one myself and it's the best £7 I've ever spent! It's really easy to use and nice and heavy.
  11. TMM
    TMM Modder
    12 Jan 2004
    i've never had a problem taking off molex plugs with a small jewellers screwdriver, but those tools are handy aswell.
    Its also a good idea with sleeving lines with multiple molex connectors, to tape up the metal pins as to keep them as slim as possible so its easier to get your sleeving and heatshrink over them. If you stagger them in pairs of two it makes it thinner:
    http://www.bytesector.com/reviews/id-295/img39.jpg
    Another excellent idea is to melt the ends of the braiding (with a lighter or other flame source ;)) a little before "threading" them onto the cable - that way they won't frey(sp) :)
