Cable Splitter
Discussion in 'Hardware' started by JoJo2201, 18 Dec 2005.
  1. JoJo2201
    JoJo2201 What's a Dremel?
    13 Nov 2005
    So, I was looking for a jacket in my room, when i came across an old ATI video tuner. My first though was sweet!!, but then i realized i dont have a way to get the cable to my computer, does any one know of a way to split the signal between my cable that goes to my TV and one for the card? I would really like to use this card, so any help would be good. thanks.
  2. Zach
    Zach What's a Dremel?
    29 Jul 2005
    is it cable signal or normal tv signal ? spliters can be bought at maplins for both types but for cable signal make sure u get right one.
  3. JoJo2201
    13 Nov 2005
    Its just basic cable that i pay $25 a month for it (so im assuming its not just a tv signal), anyways, i was just wondering if there is anything that can split a single cable connection into two independant ones? so that i could capture one channel on my comp and watch something else on my tv.
  4. JoJo2201
    13 Nov 2005
    Ok, i did some searching, i learned that when a cable signal is split with a splitter (like this one), each signal is independant, i can watch any channel on my PC and then any channel on my tv with no loss in quality!!
  5. scifi3018
    scifi3018 Minimodder
    6 Feb 2005
    lmao
    all you need is one of these linky for les than 2$
    If you look outside your house, you only have one cable line that runs to it, and somewhere under a (probally) grey box there is one of these assuming you have cable in multiple rooms. This is what the cable company uses (prolly a no-name though) and will suit well enough.
    And with cable, there is no such thing as an independant signal (tv, dunno about cable modems). The one cable line carries all the channels that you buy at different frequencies (channels) so there is no "personal" signal
  6. crazydeep74
    crazydeep74 What's a Dremel?
    25 Jul 2005
    Actually thats wrong, there is loss in signle, but usally just between a couple tvs' the loss is so minute you cant detect it. Although on larger systems, like at my house, the picture can get real bad.
