Modding CableMod PSU cables now available to purchase from Overclockers UK
Discussion in 'Article Discussion' started by Combatus, 19 Dec 2014.
  1. Combatus
    16 Feb 2009
  2. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    They are a bit on the pricey side at £69.95 a kit, they do look really well made though. I don't suppose the range will be extended to Fractal Design or Thermaltake PSU's will it ? or any other brands for that matter ?
  3. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Unlikely atm I'd say, especially for Fractal as OcUK don't stock their products as far as I know. There's a chance of cross-brand compatibility if one brand happens to use the same OEM and the same connectors as those brands listed in the press release, but I'd say it was best to stick with listed compatibility to be sure :)
    Dave Lister likes this.
  4. Dave Lister
    1 Sep 2009
    Ah ok thanks man, i'll keep hunting around in that case.
  5. Sim0n
    Sim0n rm -rf /
    14 Dec 2001
  6. ZoomRGS
    ZoomRGS What's a Dremel?
    31 Oct 2013
    Thank you very much. I have learnt the art of braiding cables myself over the years and pretty pleased with the results I get.
  7. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    These look very lux, but they cost almost as much a some of the PSU they are for. I really would love to pick up a set like this for my SS460FL-I though. Too bad they don't make a cheaper 'mini' set with just 24 pin, EPS, 2 6pin pci-e and a sata... I don't really need all those others.
  8. fluxtatic
    fluxtatic What's a Dremel?
    25 Aug 2010
    Offering them a la carte would be nice - seems they're offering a pretty complete set, but it's more than most people would need
  9. Parge
    16 Jul 2010
    £70 per kit.
    They must be having a laugh.
    I am never, ever, ever, going to spend that for coloured cables.
  10. Chris_Waddle
    Chris_Waddle Loving my new digital pinball machine
    26 Mar 2009
    I braided many a cable in my years and when it came to my last build I just couldn't face the prospect of a full system again. The time it takes, the cost of the materials, frustration, swearing and broken ATX pin removal tools just wasn't worth it.
    I specifically went for a Corsair power supply because they sold pre-braided cables. They cost over £75 (the ATX cable is sold separately to the peripheral cables) and to me were worth it for the look and ease.
    If I was building my system again, I would certainly go for these cables as they look slightly better and are slightly cheaper. I also like that I would be able to have a choice of power supply manufacturer too.
  11. Waynio
    Waynio Relaxing
    20 Aug 2009
    Convenient good to go kits with OK range of colours, I like the fact they are skinny & don't use heat shrink, easier to manage & look better.
    £70 is a good price IMO, cheaper than going full custom DIY & without the hassle.
  12. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Well this is going to save a lot of painstaking hours. About time
  13. DraigUK
    DraigUK Minimodder
    9 Apr 2009
    They look great, but that price....jeez.
  14. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    I keep seeing that, but these seem to be the cheapest (good quality) pre-braided cables I can find, they're an order of magnitude cheaper than a custom job (think north of £120 for the same cables in this kit) and it saves hours of cable sleeving, which I hate.
    Sleeved and coloured cables are a pretty specialist thing so they'll always be dearer than plain ones, but for the relative quality and number of parts these look pretty reasonable.
    All that's missing is some SATA cables for drives...
  15. Waynio
    Waynio Relaxing
    20 Aug 2009
    I watched the OC3D review posted above & they come with SATA cables, it's a complete replacement set.
  16. fix-the-spade
    4 Jul 2011
    I meant the data cables as opposed to power, can't have a braided power set and then leave the cables from the drives to the board naked, that's just not on.
    Even some short extensions would do, just so the loop where they connect to the board matches whilst the drive end is easily hidden.
Tags: Add Tags
