Modding Cadillac XLR Nano Dock
Discussion in 'Modding' started by FranjoBalls, 30 Oct 2006.
  1. FranjoBalls
    FranjoBalls New Member
    30 Oct 2006
    Just thought I'd pop this in this forum, nothing really PC related though. When I got my nano I didn't get a dock with it, so after seeing the article under the modding tab I decided to try it, click the pics to enlarge them.
    Room under the tonneau cover:
    Got this idea from the front page as well, using the elastic band to hold down the tabs so the nano can plug in easily:
    Hole cut in tonneau cover, not the cleanest but you can't really see it:
    I thought about having it sit right on top like this, but ended up not liking the look of it, wanted it lower:
    Pics of the nano sitting in it:
  2. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    It is a functioning dock correct. As in the ipod does actually connect to your computer with it? Otherwise It is a very cool looking mod. I like it :thumb:
    Oh and, welcome to the forums! :thumb:
  3. FranjoBalls
    30 Oct 2006
    It is functional, basically the usb cable runs from the back of the computer through the under body of the car. I used electrical tape to secure the ipod connecter to the body of the car on the inside. So basically whenever i want to sync up music to it, or charge it, just plug it in the tonneau cover.
  4. SIMSY
    SIMSY New Member
    7 Sep 2006
    i would love to see apple make real versions of this for advertisement lol,
    i'd love to see a big ipod in a car go past my house lol
  5. Warrior_Rocker
    26 Jun 2005
    Just wondering, does not the sync cable use locking clips to hold the cable in the iPod. Unless yours is different how did you work around that.
  6. FranjoBalls
    30 Oct 2006
    I took an elastic band, and wound it around the locking clip about 15 times to keep it depressed in, so i can just plug the nano in it easily, you can see that in the 2nd pic.
  7. Warrior_Rocker
    26 Jun 2005
    'doh I see it now, I was wondering what the rubber band was for exactly. Glad it worked out for you. :dremel:
