Electronics Calculator LCD -> Computer?
Discussion in 'Modding' started by davidbacsik, 19 Jul 2006.
  1. davidbacsik
    davidbacsik What's a Dremel?
    23 Apr 2006
    I imagine there's a reason you can't hook up a calculator LCD to a computer if you built a controller, but could someone inform me of why? I haven't found any answers on the interent, and I have limited electronics knowledge.
  2. woodshop
    woodshop UnSeenly
    14 Oct 2003
    your right but for the wrong reasions really..
    you COULD hook up the Calc LCD if you HAD a controler. however it's eather the controllers cost 400$ or you/we can't build them.
  3. bender386
    bender386 What's a Dremel?
    5 Jan 2006
    what type of calculator screen? a simple 7seg display? or one of those fancy graphical calculators
  4. davidbacsik
    23 Apr 2006
    7-segment
  5. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Those shouldn't be a problem at all to hook up. As long as you can write software for it.
    i remember someone made a CPU meter from 2 7sec LED displays. I guess you could use some of the same methods. I can't remember where i saw it, though.
  6. ch424
    ch424 Design Warrior
    26 May 2004
    No, you can't Smilodon: LCDs are very different to LEDs. They need a specially regulated AC input. You might be able to hack a different chip to work with the LCD, but using a PIC/plain logic will probably be a bit tricky.
    ch424
  7. Smilodon
    25 Mar 2003
    of course you'll need a driver chip for the LCD itself, but those come in many versions and prizes. Shouldn't be too expensive or advanced.
  8. Confused Fishcake
    Confused Fishcake Minimodder
    25 Sep 2005
    It would be quite easy if you went about it a different way. All of the buttons on a calculator are multiplexed - you need at most 5 wires. Hook these up to a pic, and write some clever code (or even resort to 1+1+1... etc.) I've tried it and its not very hard. Most calculators can handle very fast inputs, so you don't notice any flickering.
  9. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    He's got a pretty good point, especially if you just want numbers, just have the computer mash the clear button, then send the number you want displayed.
  10. crazydeep74
    crazydeep74 What's a Dremel?
    25 Jul 2005
    "They need a specially regulated AC input"
    You mean theres an inverter in every calculator/PDA ive ever owned?
  11. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    LCDs, I guess maybe now the cheap display ones, are usually driven by a low frequency square wave that is 180 degrees out of phase with the data in signal per segment.
    Ex.
    10101010 <-Backplane
    01010101 <-Input to a segment that will show
    10101010 <-Input to a segment that will not show
  12. ConKbot of Doom
    2 Jul 2003
    yes, LCDs need AC to operate, depending on the kind, it can be very low frequecy I believe that on some text LCDs the frequency can be like .5hz (yes, 2 seconds per cycle)
    I forget exactly how it works now, I think on the text displays, the bias followed the AC waveform, the signals for each pixel were opposite if they were on, and in phase if they were off, or something to that effect.
    Doesnt have to be a nice sinewave AC btw, I think squarewave is ok, but I think that all of that would make constructing your own driver circuit... interesting.
    EDIT: haha Xiachunyi beat me
  13. Sputnik
    Sputnik What's a Dremel?
    1 Sep 2005
    I have many LCD 7-segment displays from calculators. I remember years ago, when I was stupid, I took a 7-segment LCD calculator display and attached a 1.5v cell to random contacts until I got a few segments to 'light up'. I then went and did something else to occupy myself. I don't know if I damaged it or anything, I didn't see any smoke so...
    Sputnik :lol:
  14. mbates14
    mbates14 What's a Dremel?
    25 Nov 2005
    the ATmega169 has a built-in LCD controller. you will have to write some firmware for it, but it shouldnt be too dificult. :)
