Planning Call of duty modern warfare 3 case mod
Discussion in 'Modding' started by fractal arc modder, 19 Nov 2011.
  1. fractal arc modder
    fractal arc modder What's a Dremel?
    12 Aug 2011
    Hey guys,
    Im planning on modding out a Fractal Design Array 2 nas case.
    Mods im going to be carrying out are:
    Top fan hole for a full size atx power supply,
    Cutting both sides out to see threw the case,
    Top panel im going to be cutting out the modern warfare 3 lettering,
    Im going be using dog tags for components the case will have inside it,
    Adding custom case feet,
    Painting camouflage on both sides and adding perspex to both sides,
    Using cross hair fan grilles to top and side,
    Adding a green led light at the top of the case to light up the modern warfare 3 logo,
    Slim line dvd drive in the front of the case,
    Making a custom dvd drive mount and solid state drive mount at the front of the case,
    Sleeving the power supply cables green and black,
    Adding bullet holes in the perspex
    And various others as the work log progresses.
    The parts im planning on using are:
    Asetek 570lc cpu cooler,
    Intel i7 2600k cpu,
    Gskill 8 gig ddr3 2133mhz ram,
    Zotac z68 itx wifi motherboard,
    Silverstone 850watt psu,
    Sapphire or Amd 6970 2 gig card,
    Corsair or kington solid state drive
    And a sony dvd drive slim line.
    Here are the designs:
    front view
    side view 1
    side view 2
    Top view
    I will commence the case mod when everything arrives that i need.
  2. rastaman46
    rastaman46 What's a Dremel?
    22 Oct 2011
    Who cares about garbage MW3 game?
