Case Mod - Complete CALL of DUTY WARZONE
Discussion in 'Project Logs' started by pccustom, 9 Apr 2021.
  1. pccustom
    pccustom Multimodder
    12 Jul 2017
    Hi guys soon available hardware list new mode coming remains tuned ....
  2. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
    Go Johnny go, go... :clap:
    pccustom likes this.
  3. pccustom
    12 Jul 2017
  4. pccustom
    12 Jul 2017
    first components arrived..
    MADPC likes this.
  5. pccustom
    12 Jul 2017
    disassembling case
    first coat primer.
    censored_Prometheus_ likes this.
  6. pccustom
    12 Jul 2017
    after one coat of primer, opaque military green undercoat
    the vegetated mimetic involves the use of branches, leaves etc., in this case I use pine twigs, but the effect changes according to the support used
  7. pccustom
    12 Jul 2017
    Go a head with the second coat..
    4LIEN, Cheapskate, MADPC and 3 others like this.
  8. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Very cool effect :rock:
  9. pccustom
    12 Jul 2017
    Continue with last camouflage color a yellow khaki
    Next step interior panels
  10. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Interesting this new project! :dremel:
  11. pccustom
    12 Jul 2017
    this case has both side panels in glass, I prepare a cover that in addition to acting as a cover for the cables will give more character to the whole mod!
    this panel is a bit complex it will take a while to finish it and I still have to define well the logos and lights to complete it with other ribs
    Cheapskate, 4LIEN, ivory2k19 and 3 others like this.
  12. pccustom
    12 Jul 2017
    Hi guys you proceed with the side panel a bit complex and laborious but it's worth it
    All panels are undincollated with a superchlant for acrylic.
  13. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    That paint is insane cracking build mate:thumb:
  14. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Impressive work on that plexi! :jawdrop: Look like its made from a CNC machine!
    kim and pccustom like this.
  15. pccustom
    12 Jul 2017
    Painting of the internal side panel There will always be tempered glass panels closing everything
    This panel serves to hide the cables, and give illumination as well as to further customize the case.
    graphics applied before painting, Under this panel the LEDs will be positioned
    For the most demanding videos with music!!!! ....
    dOxOb, Cheapskate, ivory2k19 and 3 others like this.
  16. ciaognep
    ciaognep Minimodder
    10 May 2020
    I love C.O.D. theme!!!! well done!:jawdrop:
  17. pccustom
    12 Jul 2017
    PSU cover consisting of 3 pieces will be positioned leds between the panels with a layered effect ...
    I had to make a hole (which will be hidden with another panel) for the power supply installing it upside down, i.e.
    the fan at the bottom, there was not enough ventilation ...
    as this will be a real GAMING BEAST a good cooling first of all ..
    ready to paint!!
    in the meantime, another package from PCHUNTER.IT what will it ever be?
    Cheapskate and Jean R built like this.
  18. pccustom
    12 Jul 2017
    conclusion of the cover psu compost from 3 pieces classic cover folded at 90 °
    which serves me as a support to add the other 2 in the middle of the leds that will illuminate the logos
    and show light between the panels these threaded inserts are great!!
    let's mount
  19. pccustom
    12 Jul 2017
    hello guys today a lot of stuff .. let's go! ssd painting ..
    disassembly, coat of primer and same painting of the case.
    realization of the SSD housings, a case cover panel on which the bracket is mounted
    will have an extra led panel to cover the cables
    I decided to customize the deepcool AIO logo by replacing it with my own .... what a megalomaniac I am ...
    here is the central part with the leds reflecting the light from below, there is a small panel, I cleaned the support and applied the logo cut out on vinyl.
    et's proceed with the rest radiator themed painting
    customization of motherboard elements ... always in a vegetated camouflage theme
  20. pccustom
    12 Jul 2017
    cuntom logo on deepcool castle 360 v2
    ivory2k19 and 4LIEN like this.
