News Calling all folders - your folding team needs you
Discussion in 'Article Discussion' started by arcticstoat, 5 May 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    Not sure if my Q6700 + 8800GTX would make much of a dent, but I guess every little helps.
  3. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Every little helps, and those two combined will generate quite a few points :)
  4. eddtox
    eddtox Homo Interneticus
    7 Jan 2006
    I've joined the team (as elepedus) and set up the SMP client on my i5-760. All four cores are ticking along at 100%.
    I would like to get my HD5770 folding too, but I think I will need some advice as I downloaded the gpu2 console client and the latest drivers from AMD, but it says that my gpu is not supported.
  5. Puzzu
    Puzzu What's a Dremel?
    5 Feb 2009
    I don't think my single core Revo will make any dent at all.....
    My q6600 + gtx260 is without PSU :(
  6. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Thanks for joining in. It's been a while since I folded on an AMD card, but iirc the GPU3 console client will run better on your card.
  7. TARIKK
    TARIKK Minimodder
    19 Feb 2009
    Count me as well, i have a 2600k and a pair of 5850. So whats next, i'll be at home in an hour so i can start, but as i'm not very experienced on this i may ask for some help to be sure that everything is right with the setup.
  8. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Am leaving work now but soon as I get home later I will put up a few useful links to get you going and set up your clients, well of no one beats me to it anyway :thumb:
  9. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    This is the client for the CPU here:
    http://folding.stanford.edu/English/DownloadWinOther
    Its the "Windows XP/2003/Vista/2008/7 SMP2 client console version" client you want for it.
    Also this was posted by Lizard earlier in another thread:
    http://forums.bit-tech.net/showthread.php?t=167138&page=4
    That will get the CPU doing bigadv, need to have it running 24x7 to get the points. If you don't have the PC on 24x7, remove the -bigadv flag and put in -advmethods instead.
    For the GPUs, follow this guide:
    http://folding.stanford.edu/English/WinGPUGuide#ntoc4
    The link for the GPU3 client you need is the first I posted, you want the following version: "Windows XP/2003/Vista/7 GPU3 (required for Fermi) no-nonsense console client."
    Also, its worth getting fahmon to keep an eye on the clients progress and PPD:
    http://fahmon.net/
  10. Neophyte4Life
    Neophyte4Life What's a Dremel?
    24 Feb 2009
    My MPI seems to be working so you now have 24 opteron cores and one gtx275. (luckily i am not responsible for powering the 6 opterons)
    Noob4Life2
  11. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    Yes, GPU3 is the best client for AMD cards.
  12. eddtox
    7 Jan 2006
    Well.. got the gpu working (using gpu3 client -thanks), but its only doing 1% every half an hour, and for some reason my cpu client doesn't seem to register the right username (fahmon says it's anonymous :( )
  13. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    debating dropping in my 2500k and 460 1Gb
  14. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    That sounds far too slow for a 5770. What does Fahmon say the ppd is? It should be around 2,500 if its working correctly.
    For the CPU, if you're running the console client, close it, then run it again from the command line with the following added to the end:
    -config
    This will then make it enter config mode, where you can set all sorts of parameters, including the username and team number. The former should be CustomBitChimps (character sensitive) and the latter should be 35947.
Tags: Add Tags
