Other Cam mount thread size?
Discussion in 'General' started by total zombie, 17 Mar 2016.
  1. total zombie
    total zombie What's a Dremel?
    2 Nov 2009
    hi, can any tell me what tap size i need for camera screw in mount?
  2. Arboreal
    21 Jan 2011
    The standard (small) size is 1/4" with 20 threads per inch, what used to be called 1/4" Whitworth.
  3. total zombie
    2 Nov 2009
  4. Arboreal
    21 Jan 2011
    That looks to be the one. Wikipedia has this to say about tripods; so if that's correct, you have it.
  5. johnnyboy700
    johnnyboy700 Minimodder
    27 May 2007
    Its also the same diameter and thread pitch as the common American size 1/4 UNC. The only difference is the angle of the thread (engineer mode engaged), 1/4 BSW (British Standard Whitworth) has a 55 degree angle whilst UNC has a 60 degree angle. For just about every conceivable application they are the same.
  6. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    Great thread thread!!
  7. Arboreal
    21 Jan 2011
    The inner Engineer is strong in this one! :dremel: Nice info, been using tripods for decades and never knew that :D
  8. total zombie
    2 Nov 2009
    cool thanks alot :)
