Apple Can a mac person please help me?
Discussion in 'Software' started by MrMacomouto, 29 May 2006.
  1. MrMacomouto
    MrMacomouto What's a Dremel?
    28 Mar 2004
    I am after a 1280*1024 screen shot of your desk top, preferable tiger, but any OSX would do...
    Want to fool some mates with my windows desk top...
  2. MrMacomouto
    28 Mar 2004
    Oh umm ****, can I get it non-compressed to? If you need an FTP to upload it to I can get one for you...
    or just add me to MSN, mrmacomouto@gmail.com
  3. simon_C
    simon_C Minimodder
    13 Nov 2005
    just google. or search flickr, there are plenty.
  4. adam197
    adam197 What's a Dremel?
    22 Feb 2005
    I cant give you a screenshot at that resolution as my Cube is in pieces and iBook only supports 1024x768. I can however send you the background and a screenshot which you can Photoshop if you like. I really recommend buying a Mac though. That way you get to "fool" your friend and get a decent computer.
  5. MrMacomouto
    28 Mar 2004
    Oh.. I used to be a Mac man guys but I got away from them...
    Gaming was pitful and everything was to expensive/hard to find...
    I would like to get one of those blue/orange iBooks, always had a soft spot for them...
  6. MrMacomouto
    28 Mar 2004
    All JPEG's
  7. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
  8. The cheapskate
    The cheapskate One custom title before Matty
    27 Oct 2004
    He doesnt want a jpeg image.
    (no mac sorry bud)
  9. ArtificialHero
    ArtificialHero We were just punking him sir!
    25 May 2004
    I can give you one at 1440x960, then you can scale it down. Dyou want anything open etc?
    AH
  10. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    What format DO you want it in? If not JPEG..
    And what would you like it have visable in that image?
    The dock? top bar? finder? iCal? ...
    You need to be a bit more specific
    L
  11. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    The background image is a jpeg anyway, converting that to a non-compressed format won't help at all...
  12. MrMacomouto
    28 Mar 2004
    Oh just the little dock thing down the bottom open and a few things on the desktop that makes it look like it is used.
    JPEG is okay but it has to be on the better image quality, but the equivilent of bitmap would be good...
    Oh and try not to get the mouse on the screen....
    THANKS MAC GUYS!
  13. MrMacomouto
    28 Mar 2004
    But converting it into a jpeg makes it twice as bad.
    Go and try it, get a jpeg then take a screen shot and save it as a jpeg twice. You will see what I mean.
  14. feckless2k1
    feckless2k1 Minimodder
    2 Sep 2003
    Arn't you going to have to convert it to JPEG to set it as a background? I would do it but by ibook can't do higher than 1028 :(
  15. MrMacomouto
    28 Mar 2004
    Nope, can load what ever format I want as a background.
  16. Lovah
    10 Jul 2002
    Sorry only read this when I got home. I'll try to do it on tuesday, if that isn't too late. PM your email adres so I don't have to go true all the trouble of uploading it somewhere.
    (some holiday, so no working on monday)
    L
  17. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    Sam0r to the resceu.
    Be proud, I actually deleted a whole load of crap off my desktop, unmounted my iPod and changed my resolution down to 1280x1024 just for that.
  18. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Just set that as my HTPC screensaver, cheers Sam0r :thumb:
  19. Sam0r
    24 Jun 2005
    Its not exactly a screensaver....
  20. ElThomsono
    18 Mar 2005
    It's a TFT, screensavers are just for amusement these days.
