Modding Can a WC pump be mounted updside-down?
Discussion in 'Modding' started by Thacrudd, 14 Dec 2007.
  1. Thacrudd
    Thacrudd Where's the any key?!?
    27 Oct 2006
    As the name implies, can a watercooling pump be mounted upside-down and still function properly?
  2. radodrill
    radodrill Resident EI
    14 Mar 2006
    yes
    just don't run it dry.
  3. Thacrudd
    27 Oct 2006
    if it is mounted higher than the res, then would air pockets form there over time?
  4. gnidnu
    gnidnu Beware of the Tofu!
    9 May 2006
    It's not always recommended to mount upside-down. E.g. Laing DDC manual states it must not be mounted with the motor pointing up.
  5. radodrill
    14 Mar 2006
    Primary reason for mounting the pump lower than the res is to keep the pump inlet flooded during the filling process.
    Well with most pumps it doesn't matter; the DDC must be one of the few exceptions.
  6. marcus000
    marcus000 Watercooling Mad
    7 Aug 2007
    If you mount a DDC upside down gravity will be pulling the little impeller away from it's housing.. not good!
  7. RinSewand
    RinSewand New Member
    11 Sep 2006
    Yeah, best bet would be to email the appropriate manufacturer and ask them, based on the pump you're thinking about.
    RwD
  8. Nexxo
    Nexxo Queue Jumper
    23 Oct 2001
    Some pumps do not mind in what position you mount them, as long as it is below the reservoir (waterline) and so that no air can get trapped in the impeller chamber (the pump outlet generally needs to be higher than the chamber itself). The Eheim's and older Swiftech MPC 600's are such pumps.
    In some pumps however, the impeller is balanced on a bearing in the magnetic field of the drive coil and on a lubricating cushion of the liquid that is being pumped, which minimises any friction and wear and thus ensures long life, but relies on the pump being mounted the right side up. The Laing DCC is one of those.
