Modding can anodiosed aluminium be engraved?
Discussion in 'Modding' started by RickDawson, 7 May 2007.
  1. RickDawson
    RickDawson Minimodder
    29 Mar 2006
    just wondering if it can be done
  2. jezmck
    jezmck Minimodder
    25 Sep 2003
    anything can be engraved with the right equipment.
    you may be asking whether the colour goes right through the alu - but I don't know anyway, though I assume not.
  3. RickDawson
    29 Mar 2006
    I know the color does not go right through. it's just a layer on top of the aluminium.
    There's a local trophy place, who say they do engraving.
    www.trophies-manchester.co.uk
    I will go and ask them if they'll do it.
    Should I take a small bit of aluminium when i go and ask?
  4. mattthegamer463
    26 Nov 2004
    That place would only do machine engraving of letters for trophies and plaques, not a image onto a case side. The machines are small, they aren't capable of such a large job. Best you may find is a guy with a Dremel and some skill or a specialty company on the web that does that kind of stuff, of which I've heard of a few.
  5. RickDawson
    29 Mar 2006
    it's only small engravings, but it's on a big sheet.
  6. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    you could always laser etch it
  7. mattthegamer463
    26 Nov 2004
    The problem then would most likely be not that the machine can't engrave what you want, but the holding mechanism to hold the piece is designed for maybe max 10x10cm pieces, not a large sheet, and therefore unless you want the engravings around the edges of the sheet, it couldn't be done.
    Like I said talk to them, they may have something they can help you with, or point you in the direction of someone who can.
  8. h_2_o
    h_2_o What's a Dremel?
    24 Jun 2004
    if it is an engraving only shop and the material is "hard anodized" they might not be able to do it. some hard anodized can be extremely resilient and some of the smaller engraving machines might have a difficult time with it. however cnc machines should be able to cut through it no problem.
  9. RickDawson
    29 Mar 2006
    I'll go and talk to them.
  10. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    Ive worked with hard anodized aluminum, its nothing that even a lightweight machine cant handle, its just wears on endmills quickly. If the machine can handle the aluminum, then hard anodization shouldnt present a problem to it with the righ set up.
  11. saxman
    saxman What's a Dremel?
    21 Feb 2005
    the color on an anodized piece of aluminum is a dye added to the oxidized layer on the surface of the metal. When you machine it you cut through the oxide layer where the dye is and expose the metal below the dye. This will make the etched part be not colored but will not effect the properties other than that. The hard anodizing is a thicker coating of Aluminum oxide applied to the surface of the metal. The oxide is a hard ceramic that wears aways at milling and machining bits that are meant to be used for cutting metals.
    So anyplace that does machining or engraving should have the equipment to engrave the anodized aluminum. Good luck
