Networks Can anyone recommend a good wireless card for my desktop?
Discussion in 'Hardware' started by Ljs, 4 Sep 2009.
  1. Ljs
    Ljs Modder
    4 Sep 2009
    Hi all,
    I'm moving flats next month and will need to get my hands on a wireless card for my desktop.
    I have gone through options on various on-line retailers but can't find any decent, recent reviews of them so wondered if any of you have a good recommendation?
    The wireless router will be located on the floor above me I believe...
    Nothing too expensive, but a decent bit of kit that I won't be embarrased to slap in my system!
    Thanks in advance...
  2. Fazed
    Fazed Minimodder
    5 Jul 2009
    If you have a spare PCI-E slot, (1x, 4x or even 16x), I highly recommend the Abit AirPace Wifi PCI-E card.
    Rock solid connection, easy setup and cheap! A no brainer at under a tenner!
    http://www.scan.co.uk/Products/Abit...rd-with-Antenna-and-Software-AP-A-World-First
    http://www.bit-tech.net/hardware/networking/2007/06/24/abit_airpace_wifi_pci-e_card/1
    EDIT. Scan's delivery charges are too high.
    Microdirect can supply inc. del. for £11.28
    http://www.microdirect.co.uk/Home/Product/16369/Abit-AirPace-PCI-Express-Wi-Fi-Card802-11b-g
  3. Ljs
    Ljs Modder
    4 Sep 2009
    Cool thanks, I did actually see that review on BitTech but thought there might be something newer about as it was in 2007...
    But I guess you are right - at £10 or so its a bit of a bargain and also gives me a bi fo flexiblity should I need to position the aerial slightly.
    Thanks for the retailers links, made my job nice and easy!
  4. sanins192
    sanins192 What's a Dremel?
    24 Aug 2009
    Yes, that's exactly what I did the other week. Went to order it from Scan put was faced with £7 delivery. Went to MicroDirect and it was a lot cheaper.
    A great card!
  5. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Consider a USB one and an extension cable, the short distance will make quite some difference, more than you'd think
