Windows Can choose which partitions to clone
Discussion in 'Software' started by nichos, 17 Dec 2014.
  1. nichos
    nichos Minimodder
    17 Feb 2006
    Hi
    Is there a clone program that you can choose which partitions to clone instead of the whole HD?
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    I thought all/most imaging software allowed that, i know Macrium Reflect does.
  3. nichos
    nichos Minimodder
    17 Feb 2006
    I require CLONING not Backing up.
  4. jebk
    jebk What's a Dremel?
    18 Oct 2014
    do you even google bro?
    dd, partimage, partclone, clonezilla, True Image, theres tonnes.
  5. Corky42
    30 Oct 2012
    Do you even read anything ?
    The link i provided specifically states, Disk Imaging, Disk Cloning.
    Maybe if you RTFM of the software you're currently using you would find it does what you want.
  6. nichos
    nichos Minimodder
    17 Feb 2006
    RTFM to you too made.
    If you are frustrated is no reason to use bad language
  7. Corky42
    30 Oct 2012
    Sorry but where is the bad language ?
    You asked for software that would allow you to choose which partitions to clone instead of the whole HD, and then when people attempt to help you by making suggestions you shout at them (using capitals) that you want to clone not backup, perhaps if you bothered to do as has been suggested by myself and jebk, you may actually learn that all the software that has been recommended does exactly what you originally asked for.
  8. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    hdclone can do it too, its by miray.de
  9. nichos
    nichos Minimodder
    17 Feb 2006
    Thanx Rich,
    I do not have that one but, tried the others & I could not find how to CLONE C, D & H only, & not the whole HD.
    I made an image of the whole HD & stored it in my external HD to restore in emergency with EaaseUS free.
  10. Corky42
    30 Oct 2012
    Just saying...
