Storage Can I "adapt" SATA cables for SAS?
Discussion in 'Hardware' started by KayinBlack, 22 Mar 2010.
  1. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I know that technically, all the signal wires are the same, and I'm using short runs so signal strength is no issue, can I just cut the side of the connector so it will fit and do the same with SATA power plugs?
  2. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    It should, I've done this same sort of thing before.
  3. KayinBlack
    2 Jul 2004
    Thanks a bunch, got a review to write tonight. This obviates a really expensive set of cables.
  4. KayinBlack
    2 Jul 2004
    Apparently, the drives won't initialize this way. there are extra connectors on the top of the plug, of all things...
    Have to e-mail seller, ask which cables.
  5. Splynncryth
    31 Dec 2002
    I thought that was optional. I remember having to knock out the edge of a SAA cable and power connector in the past to connect a drive.
    But if you need it, you need it.
    Out of curiosity, what type of connector is being used on the SAS card?
  6. KayinBlack
    2 Jul 2004
    Card is an Intel SRCSAS18E, drives are 4xFujitsu MAY2036RC 36.4GB.
  7. Splynncryth
    31 Dec 2002
    If it were the other type of SAS connector I might have been able to get you a cable.
    It's weird that the drive is not working, I'm pretty sure the extra pins are for a second phy so you can run the drive in wide mode. But maybe the drive won't run in narrow mode for some reason.
  8. KayinBlack
    2 Jul 2004
    Yeah, those cables are hard to get, and rather expensive.
    Any other tests I can try to make sure the drives are OK?
