Memory Can I combo this RAM together?
Discussion in 'Hardware' started by Nutyy, 11 May 2017.
  1. Nutyy
    Nutyy Widden Palettes
    24 Aug 2010
    Hey folks, long time since I tinkered with parts so I need your help,
    I currently have a 4GB (2x2) corsair XMS3 1600 MHz 9-9-9-24 1.50v DDR3 set of ram just lying around.
    I'm looking to buy an 8GB set (2x4) from fleabay. It's XMS3 1333MHz, 9-9-9-24 1.5v.
    I wanted to put both sets in my friends PC, would they be compatible? They should be right as the only difference is the 1600Mhz will run at 1333 Mhz. There shouldnt be any problems putting two 2gb sticks and two 4gb sticks in my mobo?
    Cheers,
  2. blackerthanblack
    blackerthanblack Active Member
    17 Sep 2004
    (almost) 100% sure this will be fine. While I can't speak for your particular motherboard, the specs are similar enough to be compatible. Yes, the RAM should just run at the lower speed.
    I've had mixed RAM in loads of my systems and not had a problem, though just to be sure I usually put the slower stuff in the first/primary slots.
    I've even had boards that take more than the stated capacity for some extra RAM goodness...
  3. Nutyy
    24 Aug 2010
    Cool, that's a good idea putting the slowest ram in the primary slot. So even if I don't get the same brand of RAM as long as it matches latency and voltage I should be good?
    Cheers for the help
  4. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    will be fine, just make sure its all at 1333mhz, might get away with a small overclock of 1450 ish mhz, or keep them at 1333 and tighten up the timings
  5. Behemoth
    Behemoth Timelord in training
    1 Nov 2001
    Like others have said so long as you set the speed to be 1333 MHz it should all work quite nicely. I've always found Corsair RAM to be most tolerant for doing this :)
