Graphics Can I have some advise on A Graphics Card???
Discussion in 'Hardware' started by J()£, 21 Dec 2005.
Thread Status:
Not open for further replies.
  1. J()£
    J()£ Banned
    21 Dec 2005
    I NEED YOU HELP!​
    I am planning to get my 2nd ever graphics card, and I need some advise on what to get?
    The 1st card I got wat a Nvidia GeForce 6200, 256mb, AGP :duh:
    I am planning to make my 1st PC and I am in search of PCI-Express. So far I am thinking about getting the Nvidia 6600GT 256mb, or a 6800GS 256mb???
    What are your oppinions??? Have you got any other sugestions on a PCI-EX card for about £90-£140???
    :thumb: Thanks for reading my 2nd ever thread :thumb:
  2. hitman012
    hitman012 Minimodder
    6 May 2005
    The HIS X800GTO 256MB and 6800GS 256MB would be my recommendations.
  3. J()£
    J()£ Banned
    21 Dec 2005
    Cool, Yes my mate has that ATI. It looks amazing.
    Thanks again for the cool advise :thumb:
  4. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    Too right :thumb: though i would consider the sapphire x800 gto2
  5. hitman012
    6 May 2005
    Problem is that most of these have been snapped up, and the newer non-GTO2 ones don't unlock :sigh:
  6. J()£
    J()£ Banned
    21 Dec 2005
    Ok then mate (Fr4nk).
    But as you overclock yours, Will mine still look as good without overclocking it??? :idea:
  7. hitman012
    6 May 2005
    You can overclock the HIS one that I recommended by 100MHz and it'll still be in warranty. It comes with a very quiet and efficient cooler that will facilitate this without reducing the lifespan significantly :thumb:
  8. J()£
    J()£ Banned
    21 Dec 2005
    Ok then hitman, I may try that.
    About how much do these Cards cost???
  9. Fr4nk
    12 Mar 2005
    Hmm, the GTO/2's are still quite good on stock speeds but if don't want to oc, then go with the 6800GS, then you also have the option to buy another one later on and run them in sli :thumb: (or upgrade to a 7800gt/x)
    EDIT:
    - X800GTO's
    - 6800GS
  10. Payne280
    Payne280 What's a Dremel?
    19 Oct 2005
    i'd go with the 6800GS and do some overclocking on it
  11. J()£
    J()£ Banned
    21 Dec 2005
    No Thanks Mate, I am NOT overclocking any of my hardware and killing them off like it does.
    Thanks for the post any way. :D
  12. Payne280
    19 Oct 2005
    oh well to each his own, but even on stock settings the 6800GS is a good card
  13. J()£
    J()£ Banned
    21 Dec 2005
    Nice one! :thumb: Cheers for the Info mate :thumb:
  14. Plesuvius
    Plesuvius What's a Dremel?
    22 Dec 2005
    If you're getting an X800 value card and there is any question mark on whether it will unlock for you, or it'll work after that, then i'd recommend you dont bother with all that and get a cheap and cheerful X800XL. The price difference is minimal, and although it probably wont clock as high, its 16 vs 12 pixel pipes so there is a 33% bonus right there. In theory at least!
    I have had a x800xl for many months and the performance is still excellent even in newer games. On the other hand, i havent looked into the 6800 GS, perhaps thats a better deal still. SM3 et al.
  15. Tim S
    Tim S OG
    8 Nov 2001
    If you're not overclocking, get the XFX or Leadtek GeForce 6800 GS Extremes - they're nearly as fast as a 6800 Ultra as both manufacturers have overclocked to 485/1100MHz from 430/1000MHz. It's factory clocked at those frequencies and thus guaranteed under warranty.
  16. J()£
    J()£ Banned
    21 Dec 2005
    Cool, Cool cheers mate! :D
  17. J()£
    J()£ Banned
    21 Dec 2005
    Come on... more ideas?
  18. Mister_Tad
    27 Dec 2002
    heres an idea:
    Think before you post, dont dig up 11 different threads with the same post
    bye
Thread Status:
