Modding Can I mix these two liquids?
Discussion in 'Modding' started by Thacrudd, 10 Dec 2008.
  1. Thacrudd
    Thacrudd Where's the any key?!?
    27 Oct 2006
    I have these two different liquids, both of which are blue. I've never done WC before so I really don't know how much it will take. Does a standard CPU-GPU loop take more than 1 bottle? Thanks!
  2. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    There should not be anything stopping you mixing them, but if one is none conductive and the other is not, you will end up with a conductive liquid.
    also my loop in my sig only uses about 750ml to fill. so one bottle should be enougth.
  3. Cheapskate
    13 May 2007
    Even with my obnoxious reservoirs, I've never managed to use more than one bottle.
  4. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Don't mix them. Throw the one on the right as far from you as you can. That stuff is just plain nasty.
  5. Thacrudd
    27 Oct 2006
    I kinda figured it was considering it came in the same bottle as motor oil :hehe: JIC, if I do need more than one bottle do you think I should use water or the stuff on the right?
  6. talladega
    talladega I'm Squidward
    18 Aug 2007
    I used about 750ml in my current loop with no reservoir.
    I think I am a bit wasteful with tubing. :lol:
    Anyways, I would recommend you use Feser One coolant instead of either of that. You can get it at Performance PC's
