Can I record a Realplayer stream?
Discussion in 'General' started by bradford010, 18 Feb 2002.
  1. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    I listen to radio 1 through RealPlayer and want to record it. Addicted to plaice on Moyles' show is funny as ****! Anyone any idea if/how this is possible?
  2. CaRRiT
    CaRRiT What's a Dremel?
    5 Jan 2002
    go to here and its at the top of the list of downloads.
    Hope that sorts ya :D
    CaRRiT
  3. batsman
    batsman the quiet one
    14 Nov 2001
    as far as i know you can't record the stream directly, but if your sound card lets you just record it as it's beinging streamed you will have to select 'what you hear', 'loop' 'wave output' as the source for recording and it should record what your sound card is playing to your speakers
  4. Jaz
    Jaz Banned
    18 Dec 2001
    hey man, Did you know that radio 1 stream in ogg, well you do now so that should make your life easier (you don't need real, woooooooooooohoooooooooooooooo).
    but ok you still can't record it yet, but having scoured the winamp forums (ok it was my mate who posted and told me to go look at it one day) i found the solution.
    check this out my main man
    http://forums.winamp.com/showthread.php?threadid=76240
  5. MrBadidea
    MrBadidea What's a Dremel?
    10 Nov 2001
    I have a little proggie here that does that -- PM us if ya want it.
