Windows Can not open Image
Discussion in 'Software' started by mishkat, 22 Jul 2015.
  1. mishkat
    mishkat What's a Dremel?
    15 Jul 2015
    Hi
    I have downloaded some Image from Internet and saved on my PC but now i can not open images. My windows photo viewer can"t open images. What should I do now?
    Thanks
    Mishkat
    :waah:
  2. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    The image may have become corrupted. Can you open/edit the image using paint?
  3. silk186
    silk186 Derp
    1 Dec 2014
    I would second corrupt. Try downloading them again and check the download manager to make sure they completed.
  4. supermonkey
    supermonkey Deal with it
    14 Apr 2004
    You'll need to provide a bit more detail in order to get a better response. Where did you download the images from? How did you download them (right click -> save as, or some other method)? What kind of image files are they (jpg, tif, png, bmp)?
  5. Bungletron
    Bungletron Minimodder
    25 May 2010
    whats a dremel indeed.
    can you post a url link to the image in this thread?
  6. asura
    asura jack of all trades
    22 Apr 2009
    Really? You're going there? :blush:
    Just remember OP, this is a family friendly forum :thumb:
  7. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
  8. supermonkey
    14 Apr 2004
    I know that sex sells, but now Aflac? Is nothing sacred anymore? I guess it could have been worse - it could have been pornish game hens.
