Windows Can only save pictures as .bmp?
Discussion in 'Software' started by phoeneous, 15 Dec 2004.
  1. phoeneous
    phoeneous What's a Dremel?
    16 Aug 2004
    Everytime I try to save a picture, the only option the save window gives me is "save as .bmp", eventhough the pics are .jpg's. How can I fix this?
  2. scotty6435
    scotty6435 What's a Dremel?
    4 Sep 2004
    Use a better graphics program like painshop pro. There are also many free graphics editors on the net that allow multi-format saving.
  3. 731|\|37
    731|\|37 ESD Engineer in Training
    5 Sep 2004
    It may be that your using paint on win 9x which only saves in BMP, i picked up M$ picutre it 9.0 and that will save to just about any format (and i got it in a value pack of paper and ink cartreges so i cant give you a price)
  4. quack
    quack Minimodder
    6 Mar 2002
    Is this in Internet Explorer? Clear your Temporary Internet Files and remove everything from Downloaded Program Files too. This problem is usually caused by a corrupt file in either.
  5. phoeneous
    16 Aug 2004
    I use Photoshop but that not what I was referring to. Yes, it is in Internet Explorer and yes clearing my cache helped. Thank You.
  6. quack
    quack Minimodder
    6 Mar 2002
    You're welcome, glad I could help. :)
