Build Advice Can some one help me with this build?
Discussion in 'Hardware' started by gamergod05, 9 Jun 2009.
  1. gamergod05
    gamergod05 What's a Dremel?
    5 May 2009
    http://www.ncix.com/ *note 2,000$ budget!*
    is where i plan to order from i don't know what get should i go with i7 920 or Intel quad and just overclock it and get a better gpu that way what do you recommend for a 2,000 build?
  2. GoodBytes
    20 Jan 2007
    Can you wait until December/January? if so do.
    Why wait?
    - Potential Nvidia DirectX 11 card and the release of ATI DirectX 11 card
    - New Intel CPU (new CPU socket)
    - Potential Nvidia and other chipset maker motherboard chipset release.
    - Good motherboards for the new Intel CPU.
    - Windows 7 officially release.
    - New SATA 6Gb/s standard... I don't think you can reach such speed, but it's still something.
    If not:
    You said 2,000$ and not $2,000. So I guess you wanted to say 2 000$ (metric system), and that the dollar sign location suggest that you are in Canada. If you order form NCIX, my guess is that you are in a region that you only pay 5% tax... therefore, you might fall with items that are a little more expensive than other Canadian store, but after taxes it comes to cheaper. Right?
    Ok, following 2 000$ Canadian:
    PSU: Corsair HX620 - 620W Modular PowerSupply
    CPU: Core i7 920
    Motherboard: Gigabyte EX58-UD5
    Video Card: BFG GeForce GTX 260 OC MAXCORE559 (186$ after mail in rebate, and considering that you might go with a DirectX 11 card, and it should run all games (expect for Crysis) at max settings at 1600x1200 or lower display)
    Sound Card: ASUS Xonar DX
    RAM: Corsair XMS3 Dominator TR3X6G1600C8D 6GB DDR3 3X2GB DDR3-1600 CL 8-8-8-24
    HDD: Western Digital Caviar Black 640GB 7200RPM 32MB Buffer Dual Processor SATA Hard Drive
    Case: Antec P182 (you might want to buy is locally as this case is big and very heavy.. it might have expensive shipping, so see for that)
    Optical Drive: Samsung SH-S223Q/BEBS 22X DVD+-RW SATA DVD Writer Black Lightscribe (Pioneer, ASUS is also good).
    Monitor: I don't know.
    Mouse: Logitech MX Revolution
    Keyboard: Logitech Illuminated keyboard
    WebCam: Logitech QuickCam Pro 9000
    Speakers: Logitech Z-4 2.1 or if budget allows Logitech Z-2300
    OS: Win7 RC 64-bit and purchase it when it's release. (if you Vista 64-bit for free, that will do)
    Backup external HDD enclosure (HDD not included, use your old SATA one): Vantec Nexstar 3 External 3.5IN SATA Black Aluminum Hard Drive Enclosure eSATA USB2.0
    This computer should all match (design wise) all nicely, with a modern discreet look and look nice in a room or living room.
    mm vr likes this.
  3. gamergod05
    5 May 2009
    Ya i need it soon like 2 months is what im expecting to get it just trying to get it right but im not ordering right away ya and i can't wait since my current pc is **** really old dell pc with:
    less that 1 g of ram and im running win 7 beta it going so slow and even start up slow
    and i only have a gefore 7300 gpu can't even play all lowest on games today in lowest res and for tax ya i know it will be quiet alot added i can handle extra but when parts all in not over 2,000$
