Electronics Can someone make me a round(-ish) PCB?
Discussion in 'Modding' started by Cthippo, 11 Apr 2017.
  1. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    Hey everybody,
    I'm working on a lighting system for my underwater camera rig and I need a very oddly shaped PCB made.
    Basically the way this is supposed to work is that I will solder two rows of large LEDs onto it (like these) with the center trace being one polarity and the two outer traces being the other. A cable from each trace will go up and be connected to a battery on the surface. The hole in the center goes on a 5/8-11 bolt and then the whole mess goes into a can. To prevent shorting underwater, once it's solvered up I plan to cast the whole thing in epoxy resin.
    This video shows the rig it's intended to go on:
    I know I could get the kit online and etch one, but I'm hoping someone on here has the stuff lying around and might be able to make this for me for a small cost. :rock:
  2. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    If you provide some better information on the placement of the tracks i'll do it for you.
  3. LePhuronn
    LePhuronn Minimodder
    6 Oct 2016
    Apologies for the thread jack, but how much would you charge Boscoe?
    I'm toying with the idea of a small circuit board to split SATA power around a few places and it'd look fancier than some veroboard.
