Notebooks can`t install XP on vaio...grrr
Discussion in 'Hardware' started by anderw, 21 Apr 2007.
  1. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    na man XP can be installed on it, you must be doing something silly...
  2. anderw
    anderw What's a Dremel?
    19 Apr 2007
    well more than loading the original sata drivers and showing you the pictures of the whole process i don know what to invent....i`ll take it back to the shop n see what they think...
    hanks for all your effort though.
  3. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    what bout slipstreaming the driver direct into the install cd? Just a thought...
  4. Burnout21
    9 Sep 2005
    i was thinking,
    find a disc thats bigger than the lappy one, thats IDE, very important!
    then install xp, and drop the sata drivers into the install, nothing else
    then pull the lappy disc and use an external caddy to connect and ghost the image across.
    thats the only sure way i know how, try and pull the sata drivers from the vista install.
    definate way to make it work.
  5. stratnolegs
    stratnolegs What's a Dremel?
    1 Dec 2007
  6. lalit.arora
    lalit.arora What's a Dremel?
    8 Jun 2010
    Hi Guy,
    I am having sony vaio VPCEB16FG model with window 7 and i am really fed up from window 7 and i want to install window XP. I tried suggestion given by u guys to modify bios setting but in this vaio model that settings has been disabled and i am not able to do that and second solution was use of USB floppy drive, can anyone suggest how to arrange USB floppy drive. I am having 8 GB USB pen drive can i use that as USB floppy disk drive? or please provide me any other solution.
    Thanks in advance
    Lalit
  7. bestseany
    bestseany What's a Dremel?
    2 Jul 2009
    Create a new XP disc with the SATA drivers on using nLite.
  8. Threefiguremini
    Threefiguremini What's a Dremel?
    13 Sep 2009
    Why on earth would you want to go from Windows 7 back to XP? It's brilliant
  9. iusis
    iusis What's a Dremel?
    22 Oct 2011
    i had vaio with amd motherboard windows 7now i have both 7 and xp (easy bcd needed for dual boot )
    my solution very simple- get driver from here http://files.3dnews.org/pub/drivers/ati/?desc=name .driver name- 11-6_xp32-64_raid. begin installation and choose directory to install.installer will extract package and create ATI directory.from now it is no need to continue since we have the driver in ATI folder C:\ATI\Support\11-6_xp32-64_raid\Packages\Drivers\SBDrv\SB7xx\RAID\xp driver name ahcix86 - setup information. you need it for Nlite,to integrate in your own personal setup cd. download Nlite http://www.nliteos.com/download.html or http://www.softpedia.com/get/System/OS-Enhancements/nLite.shtml. install-start load yor xp files from cd or from hdd and next next next click on integrate driver and make bootable iso then next then insert single driver and find it C:\ATI\Support\11-6_xp32-64_raid\Packages\Drivers\SBDrv\SB7xx\RAID\xp then ok and yes then next and burn the iso on blank cd.good luck! worked for me!
