Modding Can you cut IDE cables in half?
Discussion in 'Modding' started by sco0by, 19 Apr 2002.
  1. sco0by
    sco0by Mmm pie.
    12 Dec 2001
    Morning all,
    If you have a lovely shielded silver braided IDE cable - much like this one:
    What would happen if you chopped off the longer piece at the second connector? Would you be left with a very short functioning IDE cable, or a useless pile of wires! :rolleyes:
    The reason I ask is because my hard drive cage is right on top of my IDE ports on the mobo, and even the shortest cable is way too long and making the case all cluttered on the inside.
    Failing that, anyone know where I can buy very short silver braided IDE cables? :lol:
    Cheers
  2. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    I have the exact same problem mate.
    In theory yes you should be able to cut it in half and fit another connector so you have two functioning cables. I even think i've seen articles on other sites on how to do this.
    I would like to hear from someone who has done this though just so we know it will work :lol:
  3. Puk
    Puk (A shrewd and knavish sprite)
    23 Mar 2002
    I saw on a site somewhere a while ago and spotted single ended rounded floppy cables, but that was a while ago, if anyone knows of a link to them that'd be good.
  4. GunDam
    GunDam Minimodder
    9 Feb 2002
    Yeah I've seen an article where some1 has cut the unwanted end off the ide cable, and used the silver braid for cable sleaving on other components. Just make sure u make a clean cut and that no wire are capable of touching each other.
    As for adding another connect to the unwanted cut :eeek: eeekk especially on a round cable. Would be a impossible task to line up all XX (some1 fill in the number pls :D ) wires b4 push closing the connector, because the wires on ata66/133 cable are so fine its hard to punch a pin into the middle of it.
    I had ata133 ribbon where the connector was not attatched properly, it wasnt mounted 90 degress to the ribbon wires, therefore either didnt punch the wire properly or was the pins were touching more than one wire. Needless to say this ribbon didnt work :miffed:
  5. mashie
    mashie The one and only
    15 Mar 2002
    So-TrickComputers has single device Rounded IDE cables, both 9" and 18".
  6. Puk
    23 Mar 2002
    Cheers Mashie
  7. Hwulex
    Hwulex What's a Dremel?
    1 Feb 2002
  8. RoadRunner
    RoadRunner What's a Dremel?
    26 Aug 2001
    dont chopp off the long part!!!!!!!!
    if you do you will have an ATA 33 cable..
    because the edge connector on the mobo is different to the ones that go into the drives (it has a ground for every 2nd cable of the 80..)
    if you chop the short part off you should be ok though..
  9. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Yup hes right...I chopped the shorter end of my rounded to connect just one drive and it works great, just dont chop off the longer end!
  10. therider
    therider What's a Dremel?
    11 Mar 2002
    I did this with some coolermaster rounded cables it worked ok with my CD-roms, but not withh my ata100 hardisk. Think it is due to the fact 40 wires are used with CD-rom and all 80 with ATA66+
    Ever notised the hole in the ATA66 flat cables before the slave/middle plug? I think thats why my HDD didnt work with a shortened cable.
    ride
  11. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    is that the blue end?
    crap, explains alot... like why my hard disks were running so DAMN SLOW!
    thanks roadrunner, only trouble is... the cable aint the right length the other way around
    :sigh:
  12. sco0by
    sco0by Mmm pie.
    12 Dec 2001
    Could you not remove the blue connector from the end, cut the cable to the required length, then re-attach it?
    I`m gonna find out :p
  13. RoadRunner
    26 Aug 2001
    yep that will work.. you'll need to cut one of the cables though (not sure which look at a non rounded cable)
    good luck trying to crimp the cable in the right positions, i gave up & bought new cables ;)
    therider, the hole isnt why it doesnt work... if you just cut a hole it still wont work..
    the blue connector has a grounding strip that grounds every 2nd cable of the 80.. (so the signal is cleaner & therefore faster transfer rates..) the others dont
    if you just cut the hole you'll get a ata100 cable not detected message & it'll use a maximum of ata33 :)
  14. therider
    11 Mar 2002
    I thought the hole was on the cable so the mobo knows which is the master plug and which is the slave.
    Anyone got a pic of an open/uncrimped 80wire IDE plug?
    ride
  15. cpemma
    cpemma Ecky thump
    27 Nov 2001
    This link posted recently has a lot of info.
    I tried turning my cables round (blue connector to a drive) and it would'nt even boot, never mind just run slow.
    I'd make sure to configure the drive master, not cable select - cs depends on the position of the drives (last one is master), master/slave is often a bit more flexible (but YMMV ;) )
  16. MagicMikey
    MagicMikey What's a Dremel?
    31 Dec 2001
  17. Da_Rude_Baboon
    28 Mar 2002
    If i cut the cable will it affect performance?
  18. pszaro
    pszaro What's a Dremel?
    11 Mar 2002
  19. Ma Wiggler
    Ma Wiggler What's a Dremel?
    7 Apr 2002
    ack
    Wish u would of posted this yesterday morning. I just chopped my cables yesterday and i am using the shorter end. It works fine so I thought till I benchmarked it and checked it in my BIOS. I cant select anything past ata33 now. But hey it looks really nice and clean since they are about 3 inches now and no excess wire going all over the place.:eyebrow: I still have the other peices so im gonna try and and put the blue connector on and see what happens. Yippee 80 wires to connect to such a narrow thing and there all loose. Thank goodness I,m on vacation for 2 weeks.:D
  20. Ma Wiggler
    7 Apr 2002
    Were is that grounding strip in the blue connector. I didnt see one. Tore the whole thing apart (pieces, i need to learn to be patient).
