Modding Can you cut IDE cables in half?
Discussion in 'Modding' started by sco0by, 19 Apr 2002.
  1. Hwulex
    Hwulex What's a Dremel?
    1 Feb 2002
  2. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    I thought the extra set of wires on ATA100+ was to allow crosstalk between devices?
    -scoob8000
  3. mashie
    mashie The one and only
    15 Mar 2002
    No it is to prevent crosstalk (noise) between the signalling lines due to the higher speed.
  4. RoadRunner
    RoadRunner What's a Dremel?
    26 Aug 2001
    if you open up the blue connector you'll see that theres 60 crimpy bits.. (the jaggy spikey things..) & not 4 like the other 2 thing the grounding strip is the middle row..
    if you dont believe me lookup the ATA100 spec ;)
