Can you get USB 2.0 backplates??
Discussion in 'Hardware' started by couzo, 20 Jun 2002.
  1. couzo
    couzo What's a Dremel?
    26 Apr 2002
    I want to get a USB baclplate but was wondering if the USB 2.0 sockets on my mobo could fit in to my USB1.1 front plate on my Lian Li PC7 if not where can I get the USB backplates from?
  2. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    They should have come with the motherboard....
    If not, I'm not sure, but a standard one may work, since USB 2.0 still uses same ports and wiring.
  3. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    they're the same. The usb plates I got with my new board with USB 2.0 headers are the same they have been sending out with all of their other boards. The headers/wiring/sockets are all the same.
  4. Lazy
    Lazy Meow?
    13 Nov 2001
    so if i plug the usb backplates that came with my msi board into the usb 2 ports on the mobo itself it should work?
    MSI insisted that i had to but the usb 2 backplate serperatly in the manual.
    I smell i money making scam here. :worried:
  5. eddie_dane
    31 Jan 2002
    my board came with two 1.1 headers and two 2.0 headers and they sent one backplate, the manual says I can connect it to any of them for proper installation. I can order more and they only offer the one part number. The headers are the same. The fact that USB 2.0 ports are backward compatible to 1.1 or 1.0 reinforces that fact. Unless MSI did something screwy with the headers on the board :eyebrow:
  6. Lazy
    Lazy Meow?
    13 Nov 2001
    they are probably just trying to make more money.
  7. Marzupial
    Marzupial What's a Dremel?
    29 Oct 2001
    My new Gigabyte board came with 4x usb 2.0 adaptors on one back plate, plugging into 2 headers on the mobo and an extra 2x 1.1 ports on a separate backplate. It already has 2x usb 1.1 fixed to the board, so im in USB heaven, and its future proof. For a £92 board u get loads of extras.
    I really recommend it! :D
  8. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    That means that the front USB ports on the Lian li in question should be perfectly capable of running usb 2.0
  9. couzo
    26 Apr 2002
    Ok I am about to try putting the USB 2.0 in to action but before I do it why is there an extra ground plug on the USB 2.0 socket? As there are already two on the part?? Should I just ignore this plug?
  10. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    Probably for shielding purposes, to help with the higher data rates involved in USB 2.0
  11. couzo
    26 Apr 2002
    So is that really important?
