Networks Can you wireless connect laptop to 56k modem
Discussion in 'Hardware' started by JonDixon, 8 Sep 2003.
  1. JonDixon
    JonDixon Decking is the new modding
    12 Mar 2002
    Hi,
    Is it possible to buy gear which would connect a laptop wirelessly to an external 56k modem.
    Ie: if I was sat in my bedroom and I wanted to surf, I could connect wirelessly through to the modem downstairs which would dial to the net.
    I know this is possible with a cable modem as a cable modem is permanently connected but is it possible with a normal 56k'er
  2. rich_bytes
    rich_bytes What's a Dremel?
    30 Aug 2002
    Yes, a 56k connection can be shared, normally by using Internet Connection Sharing (built into windows from win98 and upwards). However this does mean that the computer with the modem attached must be switched on.
  3. JonDixon
    12 Mar 2002
    I thought a PC would be required to be connected to the modem.
  4. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    You can get a IRDA modem (infrared)
    But you would still need to be with-in 20ft.
    OR you can use a cheap server style PC connected to the modem, and use wireless networking.
  5. JonDixon
    12 Mar 2002
    Thanks for the info. Discussed it thru with my m8 who was interested.
    Have almost persuaded him he'd be better off going broadband anyway.
  6. penski
    penski BodMod
    29 Aug 2002
    Moving to Networking and Comms.
    *n
  7. Haddy
    Haddy World Domination
    22 Jan 2002
    its possible sure...but why man why? Isnt 56k slow enough....Now divide that by 2 *figurativly* and then you have networked 56k....again why man why?
  8. ceez
    ceez What's a Dremel?
    5 Sep 2003
    it aint worth it man...there's no benefit of going "wireless" at 56k....where's the joy of even using the word "wireless' when you tell a friend you have a home network!?!?! :)
  9. JonDixon
    12 Mar 2002
    It was my friend who was wanting to remote connect to his modem around the house (I use broadband).
    He's looking at buying a laptop and wanted to be able to surf in different rooms of house.
    Makes more sense to me to do it with ADSL but what can I say...
  10. ceez
    5 Sep 2003
    be the good friend that you are, make him dial the phone# to order dsl...or just send him the link! :)
