Case Mod - Complete CANIS MAJORIS (modded Tt Core X9) - Thermaltake CaseMOD Invitational S2
Discussion in 'Project Logs' started by ciobanulx, 26 Aug 2015.
  1. uerseya
    uerseya Covered in rock wool
    25 Aug 2008
    3's the magic number :thumb:
  2. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Tardy to the party as usual, but great build Alex! You just keep hitting home runs over and over. Great work!
  3. ciobanulx
    ciobanulx Modder / Watercooler
    24 Jul 2014
    Hahaha :p
    Thanks a lot mate :D Much appreciated :D
  4. ciobanulx
    24 Jul 2014
    Hi guys!
    Seems like I have another update for this build :D
    I received some goodies from ASUS and will be making some small changes to the build!
    The Sabertooth X99 motherboard has an awesome feature called TUF Detective which is a neat little Android App. It lets you control some features of the bios with ease. It lets you monitor key parameters, detect and diagnose errors and even control the PC's power status.
    Should be a neat little feature so I am implementing this tablet into the front panel of the case.
    The tablet is an ASUS Memo Pad 7 HD which is perfect for this set up. It's a great little Android tablet with a 7" IPS screen and a battery life of around 10 hours. I'm not sure if keeping it plugged into the motherboard will also charge it but I guess I will find out. I will anyway make it in such a way that it can easily be taken out.
    ASUS was also kind enough to provide an ROG SLI bridge for the two Strix 970s in the build!
    Here are the goodies!
    Comes with two SLI bridges that can be easily swapped around depending on the SLI setup of your motherboard. It also has a separate molex cable to light up the LED for older graphics cards that don't automatically light up the LED on the bridge.
    Thanks for checking it out!
    Stay tuned for the upgrade :D
    Cheers,
    Alex
  5. ciobanulx
    24 Jul 2014
    Hi guys!
    The Thermaltake CaseMOD Invitational competition has come to an end however I still wanted to do some changes on this build.
    The sidepanel covers have been added and also I've integrated the ASUS MemoPad7 into the front panel of the build, this will be used with the TUF Detective feature on the ASUS X99 Sabertooth motherboard.
    Let have a look at the progress!
    First off I pulled the acrylic off the front panel.
    A hole for the tablet to fit through was cut
    The tablet was then attached with some double sided tape to another piece of acrylic so that I can easily take it out. That is then screwed into the original acrylic piece.
    Thanks for checking it out guys and stay tuned for more!
    Will be a pretty quick upgrade :)
    Cheers,
    Alex
  6. ciobanulx
    24 Jul 2014
    Here it is guys, mostly done and ready for filling up!
    Cheers,
    Alex
  7. ciobanulx
    24 Jul 2014
    Hi guys!
    Here is the build up and running with the tablet!
    Just need to take some final pics of the build to post but it's pretty much done now :D
    Thanks for checking it out guys!
    Cheers,
    Alex
  8. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Love it! It's like the Jawas built a high-tech "clean" sandcrawler. :)
  9. ciobanulx
    24 Jul 2014
    Thanks a lot! Haha other people said it looks like that too, I guess it's a good thing :D
  10. Herodj95
    Herodj95 What's a Dremel?
    9 Sep 2011
    Fantastic, the tablet integrates very well into the mod ;)
  11. ciobanulx
    24 Jul 2014
  12. ciobanulx
    24 Jul 2014
    Hey guys!
    A set of final build pics from home to finish off the build log!
    Thanks to everyone that subscribed and followed this project, hope you've all enjoyed it!
    Huge shout out to Thermaltake for putting together such an awesome international modding event and also thank you to all the amazing companies that have sponsored this project, I'm very grateful to have been given this opportunity.
    Thermaltake, Avexir, Newegg, Performance-PCs.com, MNPCTECH.com, RAMCity, Icemodz.com and ASUS
    Stay tuned for more builds in 2016!
    For more pics and in higher quality you can check out the album on my Facebook page - https://www.facebook.com/media/set/?set=a.932174846870776.1073741852.772776719477257&type=3
    Cheers,
    Alex
  13. Gas_designs
    Gas_designs Minimodder
    29 Sep 2014
    Fantastic job, and the beautiful custom reservoirs. :clap: :clap:
  14. ciobanulx
    24 Jul 2014
    Thanks a lot mate, glad you like it :D
