Modding Cannons LianLI
Discussion in 'Modding' started by cannon, 2 Jun 2004.
  1. cannon
    cannon What's a Dremel?
    15 Jan 2004
    Hi All,
    Just finalised everything in my box.
    Let me know what you think, nothing out of the box, infact nothing huge mainly just cable management. Im not all the confident of cutting up my lian li just yet! Need a few more practice cases.
    Components are:
    p4 2.8c
    Abit IC7-g
    corsair 1024mb pc3200 pro ram
    Lian li pc70
    powercolour radeon 9700 pro
    Zalman cnps 7000al-cu and VGA heatpipe cooler
    Dual seagate 80gb SATA HDD's
    Sony DRU-510a DVD-+R/RW
    Sony CDR/RW
    Antec 550w Psu with sleeving
  2. evil_spork
    evil_spork What's a Dremel?
    4 May 2004
    looks good!
    i should get off my rear and get my lianli mod going. :dremel:
  3. modz-a-lot
    modz-a-lot What's a Dremel?
    28 May 2004
    i bet you could fit 5 more computers in that pc-75 case :D
  4. evil_spork
    4 May 2004
    seriously.. those things are freakin massive. i wanted to get one so that i coudl move my watercooling inside. right now i have the rad outside the case, it doesnt look very good :sigh:
    they just have so much room to put fun stuff in its great. i almost got one for a new comp. to have paired with my pc-61.
    wow i just noticed how amazingly clean that cable job is. thats just fantastic. i REALLY want to get some sleaving for my psu. just so much work, but i think its worth it really.
  5. cannon
    15 Jan 2004
    Im currently in the process of saving up for some water cooling gear, so when that happens ill take the dremel to the case - main thing will be to cut holes near the mobo's edge for the atx power cable and ide cables to go through.
    Also hoping to reqire the psu look so its cleaner.
    Its all in the plans, whether or not is ever happens is another questions.
    Cannon
  6. evil_spork
    4 May 2004
    the psu is VERY clean as it is now!
    did your sleeve yoru cables yoruself or have it done? im seriously considering doing it but dont know how much work that is and if its worth it.
  7. cannon
    15 Jan 2004
    Thanks for all the comments. I sleeved everything myself - took forever but i reccomend doing it. Its worth it!
    Cannon
