Linux Cannot access /dev/hda ?
Discussion in 'Software' started by Tomm, 31 Jan 2005.
  1. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    It's OK, I got it sorted. I made a few partitions using the windows disk management setup thing. AND I mounted them all in FC3. I feel so clever/geeky right at the moment! However, they aren't gonna be there when I restart are they? Do I need to update the fstab or something to kepp them mounted permanently?
    This is what I've done so far:
    Code:
    [root@localhost ~]# mount -t ntfs /dev/hda1 /mnt/windir
    [root@localhost ~]# mkdir /mnt/media
    [root@localhost ~]# mount -t ntfs /dev/hda5 /mnt/media
    [root@localhost ~]# mkdir /mnt/fat
    [root@localhost ~]# mount -t auto /dev/hda6 /mnt/fat
    Thanks for all the help, you've been great (Y)
  2. Uncle Psychosis
    Uncle Psychosis Classically Trained
    27 Jul 2003
    Yay!
    Right, when you reboot, your directories will not be mounted. However, the mountpoints will still be there because you mkdir'd them.
    So, next time you need to mount them you can just do
    #mount /dev/something -t somefilesystem /mnt/media
    for example.
    You're right in that you need to alter your fstab (to automount harddrives that is) If you do
    #man fstab
    It should explain how it works. It's pretty simple really---just a selection of columns in this order:
    <fs> <mountpoint> <type> <opts> <dump/pass>
    fs is the physical location, eg /dev/hdaX
    mountpoint is where you want it mounted i.e /mnt/media
    type is the fs type- i.e reiserfs, ext3, vfat, etc.
    opts is the options for it (i.e permissions etc---this is the hardest bit)
    dump/pass should probably just be left as 0 0--- I don't really understand what they do.
    Anyway, I hope that helps a bit. A quick read of the man pages and a google should explain it. Good luck!!
    Sam
    PS it might be an idea to make a backup of your existing fstab before you start- just in case!
