CPU Cannot disable speedstep!
Discussion in 'Tech Support' started by zhangmaster12, 8 May 2009.
  1. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    Mobo: P5b Deluxe
    CPU: e6600
    OS: Win 7 RC
    Even though speedstep is disabled in the BIOS, my cpu mult is still automatically changed from 9-6 and vice versa.
    Its annoying, especially when overclocking. This problem only occurred with Win 7, Win XP had no problems!
  2. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    What is your multiplier set at in the bios, when I first set-up my Q6700, the multi was set to 6, instead of 9:duh:
  3. zhangmaster12
    11 Jun 2006
    The mult is set to auto. Bios wont let me change it off of auto. Weird. Im using bios version 1238
  4. bullseye
    bullseye Who dares wins
    28 Apr 2009
    Did you disable C1E support as this to will reduce the multi.
  5. zhangmaster12
    11 Jun 2006
    I turned off C1E and it would still change. BUT Before, I thought the new bios would not let me manually set the multi because when i pressed enter, nothing happened, but then I realized that I just have to key in the value I want to be my multi! LOL.
