Memory Cannot get 8GB to run
Discussion in 'Tech Support' started by jimbo1951, 31 Aug 2009.
  1. jimbo1951
    jimbo1951 What's a Dremel?
    31 Aug 2009
    Hi all
    I'm new to this forum and I am seeking a bit of help with a recent build
    Abit IP35 pro xe
    Intel Q6600 slcr
    WD 500gb sata
    4gb corsair dominator 8500
    Sapphire radeon toxic HD4850
    Zalman cnps 9700 cooler
    Coolermaster CM690 case and 520w psu
    Everything is stock I have not adjusted anything in the bios, my problem is that I have 8mb of memory but cannot get the system to run with the second 4 on board.
    I have done loads of builds in the past but this is the first for about 5 years!!
    Thanks in adavance
  2. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    I'm asusuming you mean 8GB, and is your problem that the system is only recognising 4GB or that the system will not run at all with the extra 4GB onboard
  3. Rotcrack
    Rotcrack Food Maestro.
    24 Jul 2009
    What operating system do you have installed and is it a x64 bit or not?
  4. jimbo1951
    31 Aug 2009
    Apologies for being unclear, system runs fine with 4gb, add another 4gb and and does not pass the the post
  5. jimbo1951
    31 Aug 2009
    Running vista 64 ultimate
  6. andrew8200m
    andrew8200m Modder
    4 May 2009
    Could be an issue with dual sided and single sided memory. It could be that the board will ony recognise single sided memory in te remaining 2 banks. Do a quick google on your mono to find out. (on iPhone at mo so can't really do that foe you)
    andy
  7. jimbo1951
    31 Aug 2009
    Thanks for the reply, just checked Abit site says up to 8gb of dual channel
  8. Matticus
    Matticus ...
    23 Feb 2008
    Have you tried to update the bios on the board?
    I would have said to loosen the timings or speed if you had overclocked, but if everything is left as auto in the bios then that shouldn't be an issue.
    Have you tested each stick, and mix and matched the sticks to make sure its not the memory itself causing faults?
  9. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Sorry, only just read this one again, can you tell us 1.) Your exact motherboard, 2.) The exact RAM that was in your system, and 3.) The new RAM... I'm suspecting voltage issues
  10. damienVC
    damienVC What's a Dremel?
    25 Aug 2009
    Have you tried both sets of memory on their own? Could be your second batch is dodgy.
  11. saspro
    saspro IT monkey
    23 Apr 2009
    Could be different latencies or voltages in the new RAM.
    RAM get's updated quite often and the same model isn't always the same specs.
  12. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    +1 Had a similar issue on my system getting 8GB to run before I increased the voltages very slightly.
  13. jimbo1951
    31 Aug 2009
    Haven't done anything with the bios, but have mixed and matched all four modules and can get 4gb to run with any 2 modules on board so seems eack module is ok
  14. jimbo1951
    31 Aug 2009
    Board is an Abit IP35 pro xe model number is P35XEMBF003103 V1.0
    LGA775 FSB 1600. dual DDR2 1066. Memory is Corsair Dominator twin 2x4096-8500c5d, 5-5-5-15 v2.0. New is exactly the same except v2.1, however I have mixed and matched all modules and they run ok.
  15. jimbo1951
    31 Aug 2009
    Tried all in every configuration and they run ok
  16. jimbo1951
    31 Aug 2009
    Was it just on the memory?
  17. Delphium
    18 Mar 2007
    FYI... There is an edit button... USE IT!!
    Yes just the memory voltage was changed, and funny enough, its exactly the same Corsair Dominators...
    8GB, 1066MHz, 5-5-5-15 @ 2.2V working just fine.
    I found the best way was to install 2 sticks... then go in to the bios and adjust the voltage to 2.2v for the memory.
    Save and switch off, insert the next 2 sticks then boot.
    Good luck :)
    thehippoz likes this.
  18. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    I know another member was running a q6600 with 8gb of ram on a abit ip35 pro, forgot who but I don't recall him ever having problems. Have you tried updating the bios or adjusting the voltage? Are all the ram pairs the same speed?
  19. Delphium
    18 Mar 2007
    :read:
    :D
  20. jimbo1951
    31 Aug 2009
    Thanks for your reply, I adjusted the voltage through to 2.1v in stages and got the board to accept the 4 modules, however, it only read 6gb.
    I then adjusted it to 2.2v but this made no difference. Thinking I may have one duff module I have switched modules around slots in all configurations, modules are all ok but cannot get it to read more than 6gb even with all 4 modules on board.
    Is it wise or safe to put the voltage up or should I be looking at adjusting other voltages? I have to admit I'm an absolute novice when it comes to overclocking!!
