Windows Cannot move'file': it is being used...
Discussion in 'Software' started by riggs, 23 Aug 2006.
  1. riggs
    riggs ^_^
    22 Jul 2002
    Righty, I'm trying to move an avi file into a subfolder, and I get this;
    ...but I'm certain there aren't any apps open using that file?!
    I've had this before, and while I know just waiting 10 minutes is the simplest option (for me anyway), I thought I'd finally get down to finding out why this happens, and see if there's a way of listing the app/person acessing the file (I can't see why it doesn't just tell you in the first place, rather than just stating it's in use...)
    Would appreciate some guidance...
  2. Colonel Sanders
    Colonel Sanders Minimodder
    25 Jun 2002
    Well, the first thing I'd do is run hi-jack this or some other app that can tell the forum exactly what is running at the time that windows does not let you move the file. When I encounter this errror, it usually comes from one of two causes, 1) I actually have a program, fully accesable using the file, or 2) I have a process running that I cant see (think hidden system tray icon- especially with icon hiding on).
    L J
  3. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    Try using Unlocker. It was designed specifically to overcome the problem you're having:
  4. riggs
    riggs ^_^
    22 Jul 2002
    Ooh, that's perfect Hazardous - cheers for that! :thumb:
    Colonel Sanders: great suggestion, but Hazardous provided a link, and I'm too lazy to Google "hi-jack this"...thanks anyway :D
  5. simon w
    simon w What's a Dremel?
    3 Nov 2003
    Having the 'preview' panel enabled in Windows Explorer sometimes causes this.
  6. Max Tractor
    Max Tractor Minimodder
    15 Jan 2006
    A reboot will often clear it
  7. fly one
    fly one What's a Dremel?
    10 Jul 2008
    Error "can't move file it's been used by onother program"
    Thanx a lot riggs!!!:blush:
    Fly One
  8. fly one
    10 Jul 2008
    "smile, it makes people wonder what you are thinking"
  9. Hazardous
    21 Jan 2004
    I'm hurt :waah:
    :idea:
