Windows Cannot open CMD
Discussion in 'Software' started by Kronos, 7 Mar 2018.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    For some reason I can no longer open the command prompt. When I try it flashes on then disappears. I have no idea if it is related to the issues I am having with the Oculus Rift where I am getting Can't reach Oculus Runtime Services.
  2. RedFlames
    23 Apr 2009
    Can you get powershell to work?
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    Yes.
  4. RedFlames
    23 Apr 2009
    Do what you were planning to in cmd in there, and/or run
    Code:
    sfc /scannow
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    Tried that mate but zilch
  6. RedFlames
    23 Apr 2009
    Zilch as in no errors found, or zilch as in errors found but it didn't fix them.
    EDIT: May also want to give this and/or anti-virus/malware of your choice a spin.
  7. Kronos
    Kronos Multimodder
    6 Nov 2009
    Zilch as no errors found, not that it matters as it would not have helped as the issue with Oculus is an Oculus issue caused by some certificate expiring.
  8. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    Open power shell, then type cmd. See if you get any errors come up - they will remain on the screen this time instead of instantly disappearing.
  9. Kronos
    Kronos Multimodder
    6 Nov 2009
    What happened when I tried that is Powershell reduced in size to a small, really small box in the left hand top of my monitor.
  10. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Shouldn't that be "start cmd" ?
    Back OT does it do the same if you double click the cmd.exe file located in the %systemroot%\system32 folder.
  11. Zoon
    12 Mar 2001
    Windows Key and left might force it to clip to your screen edge?
  12. PaulJG
    PaulJG Minimodder
    20 Mar 2009
    I read somewhere that if you uninstall the oculus software - then reinstall with latest version, it will then patch itself with the rest of the hardware... must do mine at some point too!
  13. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    It sounds as though you've set the command prompt window size beyond or below it's minimum size?
    Can you right-click on the desktop and create a new shortcut to "C:\Windows\System32\cmd.exe" and then edit the properties of the shortcut where you should see fonts and layout tabs?
    EDIT: Shoot, just realised I replied to Kronos, not likely that he's coming back to read it me thinks but it might help someone else out.
